Источники питания сетевого напряжения на DIN-рейке MEAN WELL
Datasheet LL101C-GS08 - Vishay Даташит Диод, Шоттки, 40 В 0.03 А, SOD80 — Даташит
Vishay LL101C-GS08
Наименование модели: LL101C-GS08
33 предложений от 16 поставщиков
Диод Шоттки малого сигнала, AEC-Q101, Одиночный, 40 В, 15 мА, 900 мВ, 2 А, 150 °C
T-electron
LL101C-GS08
3.19 ₽
LL101C-GS08
5.03 ₽
ICdarom.ru
LL101C-GS08
от 12 ₽
LIXINC Electronics
LL101C-GS08
от 88 ₽
Производитель: Vishay
Описание: Диод, Шоттки, 40 В 0.03 А, SOD80
data sheetСкачать Data Sheet
LL101A, LL101B, LL101C
Vishay Semiconductors
Small Signal Schottky Diodes
Features
· For general purpose applications · The LL101 series is a metal-on-silicon Schottky barrier device which is protected by a PN junction guard ring.
· The low forward voltage drop and fast switching make it ideal for protection of MOS devices, steering, biasing and coupling diodes for fast switching and low logic level applications. · Integrated protection ring against static discharge · Low capacitance · Low leakage current · This diode is also available in the DO-35 case with type designation SD101A, B, C and in the SOD-123 case with type designation SD101AW-V, SD101BW-V, SD101CW-V · AEC-Q101 qualified · Compliant to RoHS directive 2002/95/EC and in accordance to WEEE 2002/96/EC
  • Diode Type: Schottky
  • Repetitive Reverse Voltage Vrrm Max: 40 В
  • Forward Current If(AV): 15 мА
  • Forward Voltage VF Max: 900 мВ
  • Reverse Recovery Time trr Max: 1 нс
  • Forward Surge Current Ifsm Max: 2 А
  • Тип корпуса: SOD-80
  • Количество выводов: 2
LL101CGS08, LL101C GS08
На английском языке: Datasheet LL101C-GS08 - Vishay DIODE, SCHOTTKY, 40 V 0.03 A, SOD80
