Datasheet GL41G-E3/96 - Vishay Даташит STANDARD диод, 1 А, 400 В, DO-213AB — Даташит
Наименование модели: GL41G-E3/96
Купить GL41G-E3/96 на РадиоЛоцман.Цены — от 10 до 115 ₽ 22 предложений от 13 поставщиков Дискретные полупроводники Диоды — выпрямители — одиночные | |||
GL41G-E3/96 Vishay | от 10 ₽ | ||
GL41G-E3/96 Vishay | 10 ₽ | ||
GL41G-E3/96 | по запросу | ||
GL41G-E3/96 Vishay | по запросу |
Производитель: Vishay
Описание: STANDARD диод, 1 А, 400 В, DO-213AB
BYM10-50 thru BYM10-1000, GL41A thru GL41Y
Vishay General Semiconductor
Surface Mount Glass Passivated Junction Rectifier
FEATURES · Superectifier structure for high reliability condition · Patented glass-plastic encapsulation technique · Ideal for automated placement · Low forward voltage drop · Low leakage current · High forward surge capability · Meets environmental standard MIL-S-19500 · Meets MSL level 1, per J-STD-020C, LF max peak of 250 °C · Solder Dip 260 °C, 40 seconds · Component in accordance to RoHS 2002/95/EC and WEEE 2002/96/EC TYPICAL APPLICATIONS For use in general purpose rectification of power supplies, inverters, converters and freewheeling diodes for consumer, automotive and telecommunication.
MECHANICAL DATA Case: DO-213AB, molded epoxy over glass body Epoxy meets UL 94V-0 flammability rating Terminals: Matte tin plated leads, solderable per J-STD-002B and JESD22-B102D E3 suffix for commercial grade, HE3 suffix for high reliability grade (AEC Q101 qualified) Pola
- Diode Type: Standard Recovery
- Repetitive Reverse Voltage Vrrm Max: 400 В
- Forward Current If(AV): 1 А
- Forward Voltage VF Max: 1.1 В
- Forward Surge Current Ifsm Max: 30 А
GL41GE3/96, GL41G E3/96
