Datasheet NTE6090 - NTE Electronics Даташит STANDARD диод, 30 А, 45 В, TO-218 — Даташит
NTE Electronics NTE6090
Наименование модели: NTE6090
7 предложений от 6 поставщиков
R-DUAL SCHOTTKY 45V 30A / Diode Array 1 Pair Common Cathode Standard 45 V 15A Through Hole TO-3P-3, SC-65-3
LIXINC Electronics
NTE6090
NTE Electronics
от 580 ₽
NTE6090
NTE Electronics
819 ₽
T-electron
NTE6090
78 933 ₽
Akcel
NTE6090
Производитель: NTE Electronics
Описание: STANDARD диод, 30 А, 45 В, TO-218
data sheetСкачать Data Sheet
NTE6090 Silicon Dual Power Rectifier 45V, 30 Amp, TO218/TO3P
Description: The NTE6090 is a silicon dual power rectifier in a TO3P/TO218 type package designed using the Schottky Barrier principle with a platinum barrier metal.
Features: D Dual Diode Construction: Pin1 and Pin3 may be Connected for Parallel Operation at Full Range D Guarding for Stress Protection D Low Forward Voltage D +150°C Operating Junction Temperature D Guaranteed Reverse Avalanche Absolute Maximum Ratings: Peak Repetitive Reverse Voltage, VRRM . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 45V Working Peak Reverse Voltage, VRWM . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 45V DC Blocking Voltage, VR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 45V Average Rectified Forward Current (VR = 45V, TC = +105°C), IF(AV) Per Device . . . . . . . . . . .
  • Diode Type: Standard Recovery
  • Repetitive Reverse Voltage Vrrm Max: 45 В
  • Forward Current If(AV): 30 А
  • Forward Voltage VF Max: 760 мВ
  • Forward Surge Current Ifsm Max: 200 А
На английском языке: Datasheet NTE6090 - NTE Electronics STANDARD DIODE, 30 A, 45 V, TO-218
