Ultrasonic transmitter emitted an ultrasonic wave in one direction, and started timing when it launched.
Страниц / Страница
6 /3 — 2 2. . Pr. P o. r d. o u. d c. u t. c Im. I a. m g. a e. 2 3. . 、Mo. M d. …
Формат / Размер файла
PDF / 740 Кб
Язык документа
английский
2 2. . Pr. P o. r d. o u. d c. u t. c Im. I a. m g. a e. 2 3. . 、Mo. M d. d l. u e. l pi. p n. i de. d f. e i. f n. i i. n t. t o. i n. o s. 2 4. . 、El. E e. l c. e t. c r. t i. r c. i a. c l
2.2 2. PrP or do ud cu tc ImI am ga eg2.2 3. 、MoM do ud lu el pip ni ded fe if ni in ti it oi no sn Types Pin Symbol Pin Function Description VCC 5V power supply Trig Trigger pin HC-SR04 Echo Receive pin GND Power ground 2.2 4. 、ElE el ce tc rt ir ci ac la pap ra ar ma em te et re sr Electrical Parameters HC-SR04 Ultrasonic Module Operating Voltage DC-5V Operating Current 15mA Operating Frequency 40KHZ Farthest Range 4m Nearest Range 2cm Measuring Angle 15 Degree Input Trigger Signal 10us TTL pulse Output TTL level signal, proportional Output Echo Signal with range Dimensions 45*20*15mm 3 Document Outline HC-SR04UserGuide Part1UltrasonicIntroduction 1.1UltrasonicDefinition Thehumanearcanhearsoundfrequencyaround20HZ 1.2Ultrasonicdistancemeasurementprinciple Ultrasonictransmitteremittedanultrasonicwave 1.3UltrasonicApplication Part2HC-SR04UltrasonicModuleIntroduction 2.1ProductFeatures 2.2ProductImage 2.3、Modulepindefinitions 2.4、Electricalparameters 2.5ModuleoperatingPrinciple Part3UseFreaduinoUNOtotestHC-SR04 3.1FreaduinounoandHC-SR04Connection 3.2HCSR04libraryfunctiondescription Longtiming() floatCalcDistance(longmicrosec,intmetric) 3.3AddtheHC-SR04Library 3.4TesttheModulewiththeExamplesofLibraryF
