ЭФО предлагает со своего склада новую серию преобразователей интерфейсов USB UART компании FTDI FT232RNL-REEL
Datasheet 1000Z Series (Rigol)
ПроизводительRigol
ОписаниеDigital Oscilloscope
Страниц / Страница12 / 1 — DS1000ZSeries. Digital Oscilloscope
Формат / Размер файлаPDF / 6.8 Мб
Язык документаанглийский
Datasheet 1000Z Series Rigol
Текстовая версия документа
DS1000ZSeries Digital Oscilloscope
Analog channel bandwidth: 100 MHz, 70 MHz, 50 MHz 4 analog channels, 16 digital channels (only available for DS1000Z Plus that has been upgraded with the MSO upgrade option) Real-time sample rate up to 1 GSa/s Memory depth up to 24 Mpts Up to 30,000 wfms/s waveform capture rate Up to 60,000 frames hardware real-time waveform recording and playback functions Innovative "UltraVision" technology Various trigger and bus decoding functions Low noise floor, vertical scale range: 1 mV/div to 10 V/div Built-in dual-channel 25 MHz function/arbitrary waveform generator (only for digital oscilloscope with source channels) Various interfaces: USB Host&Device, LAN (LXI), AUX Compact size, light weight, easy to use 7 inch WVGA (800x480) TFT LCD, intensity graded color display DS1000Z series is a high-performance and economic digital oscilloscope designed for the designing, debugging and educational requirements of the mainstream digital oscilloscope market. Wherein, the mixed signal digital oscilloscope aimed at the embedded design and test fields is equipped with 16 digital channels and allows users to measure analog and digital signals at the same time.
