Datasheet DS-2CD2432F-IW (Hikvision)
ПроизводительHikvision
Описание3MP IR Cube Network Camera
Страниц / Страница1 / 1 — DS-2CD2432F-IW. Camera. Compression Standard. Image. Network. • Up to 3.0 …
Формат / Размер файлаPDF / 223 Кб
Язык документаанглийский
DS-2CD2432F-IW. Camera. Compression Standard. Image. Network. • Up to 3.0 MP (2048 x 1536) Resolution
Datasheet DS-2CD2432F-IW Hikvision
Текстовая версия документа
DS-2CD2432F-IW 3 MP IR Cube Network Camera
DS-2CD2432F-IW Camera
Image Sensor 1/3" progressive scan CMOS Minimum Il umination 0.19 lux @ ƒ/2.0, AGC on, 0 lux with IR Shutter Speed 1/30 s to 1/100,000 s Lens 4 mm @ ƒ/2.0, angle of view: 79° (2.8 mm optional) Lens Mount M12 Day/Night ICR Digital Noise Reduction 3D DNR Wide Dynamic Range Digital WDR Backlight Compensation Yes, zone configurable
Video Compression H.264/MJPEG 1/3” Compression Profile Main Profile CMOS Bit Rate 32 Kbps to 16 Mbps CMOS HD Video Audio Compression G.711/G.726 Audio Bit Rate 64 Kbps (G.711)/16 Kbps (G.726) 3.0 3D Megapixel
Maximum Image 2048 x 1536 MP Camer a IR Resolution Frame Rate 60 Hz: 20 fps (2048 x 1536), 30 fps (1920 × 1080), 30 fps (1280 x 720) DIGITAL Image Settings Saturation, brightness, contrast adjustable through client software or Web browser WDR
Network
PIR Network Storage NAS Alarm Trigger PIR detection, motion detection, tampering alarm, network disconnect, IP address
conflict, storage exception, storage error Protocols TCP/IP, ICMP, HTTP, HTTPS, FTP, DHCP, DNS, DDNS, RTP, RTSP, RTCP,
• Full HD1080p Real-Time Video
PPPoE, NTP, UPnP, SMTP, SNMP, IGMP, 802.1X, QoS, IPv6, Bonjour System Compatibility ONVIF, PSIA, CGI
• PIR Detection
General Functionalities Flickerless, dual stream, heartbeat, mirror, user authentication, video mask, watermark
• IR LEDs (33 ft/10 m Range) Interface
Communication Interface 1 RJ-45 10M/100M Ethernet port
• DWDR, 3D DNR, and BLC
Onboard Storage Built-in microSD/SDHC/SDXC card slot, up to 128 GB
• Built-In Microphone and Speaker
Alarm I/O 1/1
WiFi Parameters • SD/SDHC/SDXC Card Slot (Up to 128 GB)
WiFi Standard IEEE802.11b/g/n Frequency Range 2.4 GHz to 2.4835 GHz
• Wi-Fi (WPS Connection)
Communication Bandwidth Supports 20/40 MHz Security 64/128-bit WEP, WPA/WPA2, WPA-PSK/WPA2-PSK, WPS Transmission Rate 11b: 11 Mbps, 11g: 54 Mbps, 11n: 150 Mbps
Dimensions
Transmission Range Outdoor: up to 656 ft (200 m); indoor: up to 164 ft (50 m). *Varies depending on actual environment
General
Operating Conditions -22° F to 140° F (-30° C to 60° C), humidity 95% or less (non-condensing) Power 12 VDC ±10%, PoE (802.3af) Power Consumption Maximum 5 W PIR Detection Range 33 ft (10 m) PIR Detection Angle 80° IR Range 33 ft (10 m) Dimensions (mm) 2.60" x 2.78" x 5.48" (66 mm x 70.6 mm x 139.1 mm) Weight 0.88 lbs (400 g)
Order Models
DS-2CD2432F-IW
Hikvision USA Inc., 18639 Railroad St., City of Industry, CA 91748, USA • Hikvision Canada, 4848 rue Levy, Saint-Laurent, Quebec, Canada, H4R 2P1 Tel: +1-909-895-0400 • Tol Free in USA: +1-866-200-6690 • E-Mail: [email protected] • www.hikvision.com © 2017 Hikvision USA Inc. • Al Rights Reserved • Specifications subject to change without notice. 050217NA
