Ремонт планшета Multilaser M7. Не включается. Нужна схема
5 1
14.08.2017 01:06 #1
I have a tablet of the brand Multilaser M7 quad core that simply does not turn on and the battery is with the voltage around 3.5v. When I put the tablet on the computer through the usb cable windows can not recognize the device. It would be helpful if you could find the schematic diagram of the device.
187 79
69 13
14.08.2017 06:28 #2
replace USB connector
replace battery too
https://youtu.be/4pMR1EE2ScY
1,234 65
61 33
25.08.2017 10:06 #3
Replace buttery only. Buttery is not able to supply and recieve the power.
Часовой пояс GMT +3, время: 18:20.
