Power supply printer HP Deskjet
5 1
23.10.2012 22:49 #1
I find schematic diagram HP printer power supplies?
I have a code NSW20932 (0957-2119) printed on the box with a SMD capacitor burned near a small transformer.
It uses the integrated PWM SG5841DZ
2,199 487
16 2
23.10.2012 23:14 #2
If this capa connected to pin 7(IC PWM),then his value =22micro F*25V.Good Luck.
327 26
23.10.2012 23:40 #3
Картинка, на всякий случай:
Тип файла: pdf 11_SG5841.pdf (147.7 Кб, 0 просмотров)
5 1
24.10.2012 15:37 #4
Power supply HP deskjet printer
Using the diagram datasheet sent by your friend korall_m capacitor quoted by me is the capacitor C3 code that was burned. I put a ceramic 1000pF/1000V value.
Tested and the power supply started again.
* Thank you all.
Тип файла: bmp SOURCE ATX SG5841DZ.bmp (576.1 Кб, 0 просмотров)
2,199 487
16 2
24.10.2012 16:22 #5
КораллМ-зачет!
Часовой пояс GMT +3, время: 10:48.
