OKW: приборные корпуса из Германии
Datasheets - Оптопары управления затворами - 2
Подраздел: "Оптопары управления затворами"
Найдено: 129 Вывод: 21-40
Вид: Список / Картинки
  1. Datasheet Broadcom HCNW2211-000E
    Very High CMR, Wide VCC Logic Gate Optocouplers The HCNW2211 optocoupler is an optically-coupled logic gate. It contains an AlGaAs LED. The detectors have totem pole output stages and optical receiver input stages with built-in Schmitt triggers to ...
  2. Datasheet Broadcom HCNW2211-300E
Какими будут станции зарядки электромобилей в 2030 году: лучшие решения и мировой опыт для отечественных разработок
  1. Datasheet Broadcom HCNW2211-500E
  2. Datasheet Broadcom HCNW2211#300
  1. Datasheet Broadcom HCNW2211#500
  2. Very High CMR, Wide VCC Logic Gate Optocouplers The HCNW2211 optocoupler is an optically-coupled logic gate. It contains an AlGaAs LED. The detectors have totem pole output stages and optical receiver input stages with built-in Schmitt triggers to ...
  3. Datasheet Broadcom HCNW2201-300E
    Very High CMR, Wide VCC Logic Gate Optocouplers The HCNW2201 optocoupler is an optically-coupled logic gate. It contains an AlGaAs LED. The detectors have totem pole output stages and optical receiver input stages with built-in Schmitt triggers to ...
  4. Datasheet Broadcom HCNW2201-500E
  5. Datasheet Broadcom HCNW2201#300
  6. Datasheet Broadcom HCNW2201#500
  7. Very High CMR, Wide VCC Logic Gate Optocouplers The HCNW2201 optocoupler is an optically-coupled logic gate. It contains an AlGaAs LED. The detectors have totem pole output stages and optical receiver input stages with built-in Schmitt triggers to ...
  8. Datasheet Broadcom HCNW2201
  9. Datasheet Broadcom HCNW2201-000E
  10. Datasheet Broadcom HCPL-2232
    Very High CMR, Wide VCC Logic Gate Optocouplers The dual-channle optocoupler is an optically-coupled logic gate. It contains an GaAsP LED. The detectors have totem pole output stages and optical receiver input stages with built-in Schmitt triggers ...
  11. Datasheet Broadcom HCPL-2232-000E
  12. Datasheet Broadcom HCPL-2232-300E
  13. Datasheet Broadcom HCPL-2232-500E
  14. Datasheet Broadcom HCPL-2232#300
  15. Datasheet Broadcom HCPL-2232#500
  16. Very High CMR, Wide VCC Logic Gate Optocouplers The dual-channle optocoupler is an optically-coupled logic gate. It contains an GaAsP LED. The detectors have totem pole output stages and optical receiver input stages with built-in Schmitt triggers ...
