Datasheets - DC/DC преобразователи и контроллеры Microchip - 4
Подраздел: "DC/DC преобразователи и контроллеры"
Производитель: "Microchip"
Найдено: 163 Вывод: 61-80
Вид: Список / Картинки
  1. The MIC22950 is a high efficiency 10A integrated switch synchronous buck (step-down) regulator
  2. The MIC22705 is a high-efficiency, 7A integrated switch synchronous buck (step-down) regulator
  1. The MIC22700 is a high efficiency, 7A Integrated switch synchronous buck (step-down) regulator
  2. The MIC23603 is a high-efficiency 4MHz 6A synchronous buck regulator with HyperLight Load® mode
  1. The MIC22602 is a high efficiency 6A Integrated switch synchronous buck (step-down) regulator
  2. The MIC22601 is a high efficiency 6A Integrated switch synchronous buck (step-down) regulator
  3. Not Recommended for New Designs; see MIC22705YML.
  4. The MIC4950 is a high-efficiency, 5A synchronous buck regulator with ultra-fast transient response perfectly suited for supplying processor core and I/O voltages from a 5V or 3
  5. The MIC22405 is a high efficiency, 4A integrated switch synchronous buck (step-down) regulator
  6. The MIC22400 is a high-efficiency, 4A integrated switch synchronous buck (step-down) regulator
  7. The MIC4930 is a high-efficiency, 3A synchronous buck regulator with ultra-fast transient response perfectly suited for supplying processor core and I/O voltages from a 5V or 3
  8. The MIC4744 is a high efficiency dual PWM buck (step-down) regulator that provides dual 2A current output
  9. The MIC4742 is a high efficiency dual PWM buck (step-down) regulator that provides dual 2A current output
  10. The MIC4723 is a high efficiency PWM buck (step-down) regulator that provides up to 3A of output current
  11. The MIC4722 is a high efficiency PWM buck (step-down) regulator that provides up to 3A of output current
  12. The MIC23303 is a high efficiency 4MHz 3A synchronous buck regulator with HyperLight Load® mode, Power Good output indicator, and programmable soft-start
  13. The MIC22200 is a high efficiency, 2A integrated switch synchronous buck (step-down) regulator
  14. The MIC2207 is a high efficiency PWM buck (step-down) regulators that provides up to 3A of output current
  15. The MIC23254 is a low-input voltage, high-efficiency 4MHz dual 400mA synchronous buck regulator with HyperLight Load® mode
  16. The MIC23250 is a high efficiency 4MHz dual 400mA synchronous buck regulator with HyperLight Load® mode
