Datasheet SSM2375CBZ-REEL7 - Analog Devices Даташит ИС, аудио усилитель, D, 3 Вт, WLCSP-9 — Даташит
Наименование модели: SSM2375CBZ-REEL7
Купить SSM2375CBZ-REEL7 на РадиоЛоцман.Цены — от 61 до 414 ₽ 24 предложений от 14 поставщиков ANALOG DEVICES SSM2375CBZ-REEL7 Audio Power Amplifier, D, 1Channel, 3W, 2.5V to 5.5V, LCSP, 9Pins | |||
SSM2375CBZ-REEL7 Analog Devices | 61 ₽ | ||
SSM2375CBZ-REEL7 Analog Devices | от 72 ₽ | ||
SSM2375CBZ-REEL7 Analog Devices | 89 ₽ | ||
SSM2375CBZ-REEL7 Analog Devices | по запросу |
Производитель: Analog Devices
Описание: ИС, аудио усилитель, D, 3 Вт, WLCSP-9
Filterless, High Efficiency, Mono 3 W Class-D Audio Amplifier SSM2375
FEATURES
Filterless Class-D amplifier with spread-spectrum - modulation 3 W into 3 load and 1.4 W into 8 load at 5.0 V supply with <1% total harmonic distortion (THD + N) 93% efficiency at 5.0 V, 1.4 W into 8 speaker >100 dB signal-to-noise ratio (SNR) High PSSR at 217 Hz: 80 dB Flexible gain adjustment pin: 0 dB to 12 dB in 3 dB steps Fixed input impedance: 80 k User-selectable ultralow EMI emissions mode Single-supply operation from 2.5 V to 5.5 V 20 nA shutdown current Short-circuit and thermal protection with autorecovery Available in 9-ball, 1.5 mm Ч 1.5 mm WLCSP Pop-and-click suppression
Spread-spectrum pulse density modulation (PDM) is used to provide lower EMI-radiated emissions compared with other Class-D architectures.
The inherent randomized nature of spread-spectrum PDM eliminates the clock intermodulation (beating effect) of several amplifiers in close proximity. The SSM2375 includes an optional modu
- Класс усилителя: D
- Количество каналов: 1
- Выходная мощность: 3 Вт
- Диапазон напряжения питания: 2.5 В ... 5.5 В
- Load Impedance: 3 Ом
- Рабочий диапазон температрур: -40°C ... +85°C
- Тип корпуса: LCSP
- Количество выводов: 9
SSM2375CBZREEL7, SSM2375CBZ REEL7
