Datasheet ISL9212IRZ - Intersil Даташит ИС, CHARGING SYSTEM безопасность, 12DFN — Даташит
Наименование модели: ISL9212IRZ
Купить ISL9212IRZ на РадиоЛоцман.Цены — от 48 до 231 ₽ 19 предложений от 13 поставщиков INTERSIL ISL9212IRZ IC, CHARGING SYSTEM SAFETY, 12DFN | |||
ISL9212IRZ-T Intersil | 48 ₽ | ||
ISL9212IRZ Intersil | 89 ₽ | ||
ISL9212IRZ-T Renesas | по запросу | ||
Производитель: Intersil
Описание: ИС, CHARGING SYSTEM безопасность, 12DFN
ISL9212
Data Sheet June 30, 2008 FN9280.2
Charging System Safety Circuit
The ISL9212 is an integrated circuit (IC) optimized to provide a Li-ion battery redundant safety protection from failures of a charging system.
The IC monitors the input voltage, the battery voltage, and the charge current. When any of the three parameters exceeds its limit, the IC turns off an internal P-Channel MOSFET to remove the power from the charging system. In addition to the above protected parameters, the IC also monitors its own internal temperature and turns off the P-Channel MOSFET when the die temperature exceeds +140°C. Together with the battery charger IC and the protection module in a battery pack, the charging system using the ISL9212 has triple-level protection and is two-fault tolerant. The IC is designed to turn on the internal PFET slowly to avoid in-rush current at power-up but will turn off the PFET quickly when input overvoltage is detected, in order to remove the power before any dama
- Battery Type: Li-Ion
- Number of Batteries: 1
- Диапазон напряжения питания: 4.3 В ... 6.5 В
- Battery IC Case Style: TDFN
- Количество выводов: 12
- Рабочий диапазон температрур: -40°C ... +85°C
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: TDFN
- Семейство: 9212
- Battery Management Function: Protector
- Battery Protection: Over Current, Over Voltage
- Входное напряжение максимальное: 6.5 В
- Number of Series Cells: 1
- Способ монтажа: SMD
