Datasheet SI3552DV-T1-E3 - Vishay Даташит Сдвоенный N/P CHANNEL полевой транзистор, 30 В, TSOP — Даташит
Наименование модели: SI3552DV-T1-E3
Купить SI3552DV-T1-E3 на РадиоЛоцман.Цены — от 18 до 2 231 ₽ 27 предложений от 14 поставщиков Двойной МОП-транзистор, N и P Дополнение, 30 В, 2.5 А, 0.085 Ом, TSOP, Surface Mount | |||
SI3552DV-T1-E3 Vishay | 18 ₽ | ||
SI3552DV-T1-E3 Vishay | 23 ₽ | ||
SI3552DV-T1-E3 | по запросу | ||
SI3552DV-T1-E3 Vishay | по запросу |
Производитель: Vishay
Описание: Сдвоенный N/P CHANNEL полевой транзистор, 30 В, TSOP
SPICE Device Model Si3552DV Vishay Siliconix N- and P-Channel 30-V (D-S) MOSFET
CHARACTERISTICS
· N- and P-Channel Vertical DMOS · Macro Model (Subcircuit Model) · Level 3 MOS · Apply for both Linear and Switching Application · Accurate over the -55 to 125°C Temperature Range · Model the Gate Charge, Transient, and Diode Reverse Recovery Characteristics
DESCRIPTION
The attached spice model describes the typical electrical characteristics of the n- and p-channel vertical DMOS.
The subcircuit model is extracted and optimized over the -55 to 125°C temperature ranges under the pulsed 0-V to 5-V gate drive. The saturated output impedance is best fit at the gate bias near the threshold voltage. A novel gate-to-drain feedback capacitance network is used to model the gate charge characteristics while avoiding convergence difficulties of the switched Cgd model. All model parameter values are optimized to provide a best fit to the measured electrical data and are not intended as an exact physic
- Полярность транзистора: N and P Channel
- Continuous Drain Current Id: 51 А
- Drain Source Voltage Vds: 30 В
- On Resistance Rds(on): 360 МОм
- Threshold Voltage Vgs Typ: 1 В
SI3552DVT1E3, SI3552DV T1 E3
