Datasheet LF398M/NOPB - National Semiconductor Даташит ИС, выборки-хранения усилитель 1 МГц 20 uS, SOIC-14 — Даташит
Наименование модели: LF398M/NOPB
Купить LF398M/NOPB на РадиоЛоцман.Цены — от 38 до 323 ₽ 25 предложений от 16 поставщиков TEXAS INSTRUMENTS LF398M/NOPB Sample and Hold Amplifier, 1 Amplifier, 1MHz, 20µs, 2mV, SOIC, 14Pins | |||
LF398M/NOPB National Semiconductor | 38 ₽ | ||
LF398M/NOPB Texas Instruments | 50 ₽ | ||
LF398M/NOPB Texas Instruments | от 276 ₽ | ||
LF398M/NOPB Texas Instruments | от 323 ₽ |
Описание: ИС, выборки-хранения усилитель 1 МГц 20 uS, SOIC-14
LF198/LF298/LF398, LF198A/LF398A Monolithic Sample-and-Hold Circuits
July 2000
General Description
The LF198/LF298/LF398 are monolithic sample-and-hold circuits which utilize BI-FET technology to obtain ultra-high dc accuracy with fast acquisition of signal and low droop rate.
Operating as a unity gain follower, dc gain accuracy is 0.002% typical and acquisition time is as low as 6 µs to 0.01%. A bipolar input stage is used to achieve low offset voltage and wide bandwidth. Input offset adjust is accomplished with a single pin, and does not degrade input offset drift. The wide bandwidth allows the LF198 to be included inside the feedback loop of 1 MHz op amps without having stability problems. Input impedance of 1010 allows high source impedances to be used without degrading accuracy. P-channel junction FET's are combined with bipolar devices in the output amplifier to give droop rates as low as 5 mV/min with a 1 µF
- Время выборки: 20 мкс
- Диапазон напряжения питания: ± 5 В ... ± 18 В
- Количество выводов: 14
- Количество усилителей: 1
- Напряжение смещения входа: 2 мВ
- Полоса частот: 1 МГц
- Тип корпуса: SOIC
- RoHS: да
