Datasheet LM6154BCM/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 75 МГц, 30 В/мкс, SOIC-14 — Даташит
Наименование модели: LM6154BCM/NOPB
Купить LM6154BCM/NOPB на РадиоЛоцман.Цены — от 219 до 1 663 ₽ 26 предложений от 15 поставщиков TEXAS INSTRUMENTS LM6154BCM/NOPB Operational Amplifier, Quad, 4 Amplifier, 75MHz, 30V/µs, 2.7V to 24V, SOIC, 14Pins | |||
LM6154BCM/NOPB Texas Instruments | 219 ₽ | ||
LM6154BCM/NOPB Texas Instruments | 272 ₽ | ||
LM6154BCM/NOPB Texas Instruments | 421 ₽ | ||
LM6154BCM/NOPB Texas Instruments | от 1 422 ₽ |
Описание: ИС, операционный усилитель, 75 МГц, 30 В/мкс, SOIC-14
LM6152/LM6154 Dual and Quad 75 MHz GBW Rail-to-Rail I/O Operational Amplifiers
February 2006
General Description
Using patented circuit topologies, the LM6152/LM6154 provides new levels of speed vs.
power performance in applications where low voltage supplies or power limitations previously made compromise necessary. With only 1.4 mA/ amplifier supply current, the 75 MHz gain bandwidth of this device supports new portable applications where higher power devices unacceptably drain battery life. The slew rate of the devices increases with increasing input differential voltage, thus allowing the device to handle capacitive loads while maintaining large signal amplitude. The LM6152/LM6154 can be driven by voltages that exceed both power supply rails, thus eliminating concerns about exceeding the common-mode voltage range. The rail-to-rail output swing capability provides the maximum possible dynamic range at t
- Тип ОУ: Wideband
- Количество усилителей: 4
- Полоса частот: 75 МГц
- Скорость нарастания: 30 В/мкс
- Диапазон напряжения питания: 2.7 В ... 24 В
- Тип корпуса: SOIC
- Количество выводов: 14
- Рабочий диапазон температрур: 0°C ... +70°C
