Datasheet ISL28270IAZ - Intersil Даташит усилитель, INST, RRIO, UPWR, SMD, QSOP16 — Даташит
Наименование модели: ISL28270IAZ
Купить ISL28270IAZ на РадиоЛоцман.Цены — от 72 до 288 ₽ 6 предложений от 6 поставщиков Instrumentation Amplifier 2 Circuit Rail-to-Rail 16-QSOP | |||
ISL28270IAZ Intersil | 72 ₽ | ||
ISL28270IAZ-T13 Intersil | 288 ₽ | ||
ISL28270IAZ Renesas | по запросу | ||
Производитель: Intersil
Описание: Усилитель, INST, RRIO, UPWR, SMD, QSOP16
ISL28270, ISL28273, ISL28470
Data Sheet April 13, 2007 FN6260.2
Micropower, Single Supply, Rail-to-Rail Input and Output (RRIO) Instrumentation Amplifier
The ISL28270 and ISL28273 are dual channel micropower instrumentation amplifiers (in-amps) and the ISL28470 is a Quad-channel in-amp optimized for low 2.4V to 5V single supplies.
All three devices feature an Input Range Enhancement Circuit (IREC) which maintains CMRR performance for input voltages equal to the positive supply and down to 50mV above the negative supply rail. The input signal is capable of swinging above the positive supply rail and to 10mV above the negative supply with only a slight degradation of the CMRR performance. The output operation is rail to rail. The ISL28273 is compensated for a minimum gain of 10 or more. For higher gain applications, the ISL28270 and ISL28470 are compensated for a minimum gain of 100. The in-amps have bipolar input devices for best offset and excellent 1/f noise performance. The ampli
- Количество усилителей: 2
- Input Offset Voltage: 150 мкВ
- Gain dB Min: 100 дБ
- Полоса частот: 240 кГц
- Тип выхода: Rail ... Rail
- CMRR: 110 дБ
- Slew Rate: 0.5 В/мкс
- Диапазон напряжения питания: 2.4 В ... 5.5 В
- Ток потребления: 78 мкА
- Amplifier Case Style: QSOP
- Количество выводов: 16
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: QSOP
- Тип усилителя: Rail - Rail Input / Output (RRIO)
- Семейство: 28270
- Gain Bandwidth: 240 кГц
- Input Offset Drift Max: 0.7µV/°C
- Input Offset Voltage Max: 150 мкВ
- Рабочий диапазон температрур: -40°C ... +125°C
- Тип выхода: Single Ended
- Программируемое усиление максимум: 1000
- Напряжение питания номинальное: 8 В
- Supply Voltage - Nom: 2.5 В
- Способ монтажа: SMD
Дополнительные аксессуары:
- Fischer Elektronik - ICK SMD A 10 SA
- Roth Elektronik - RE931-02
- STANNOL - 631954
