Datasheet FSAM15SH60A - Fairchild Даташит SMART POWER MODULE — Даташит
Наименование модели: FSAM15SH60A
Купить FSAM15SH60A на РадиоЛоцман.Цены — от 842 до 12 844 ₽ 18 предложений от 12 поставщиков Драйверы электродвигателей | |||
FSAM15SH60A Fairchild | 842 ₽ | ||
FSAM15SH60A, 3х фазный IGBT модуль, 600В, 15А, инвертор для управления двигателем переменного тока, [SPM32-AA] Fairchild | 1 149 ₽ | ||
FSAM15SH60A ON Semiconductor | от 4 571 ₽ | ||
FSAM15SH60A ON Semiconductor | 11 713 ₽ |
Производитель: Fairchild
Описание: SMART POWER MODULE
FSAM15SH60A
FSAM15SH60A
SPMTM (Smart Power Module)
General Description
FSAM15SH60A is an advanced smart power module (SPM) that Fairchild has newly developed and designed to provide very compact and high performance ac motor drives mainly targeting high speed low-power inverterdriven application like washing machines.
It combines optimized circuit protection and drive matched to low-loss IGBTs. Highly effective short-circuit current detection/ protection is realized through the use of advanced current sensing IGBT chips that allow continuous monitoring of the IGBTs current. System reliability is further enhanced by the built-in over-temperature monitoring and integrated undervoltage lock-out protection. The high speed built-in HVIC provides opto-coupler-less IGBT gate driving capability that further reduce the overall size of the inverter system design. In addition the incorporated HVIC facilitates the use of single-supply drive topology enabling the FSAM15SH60A to be driven by only o
- DC Collector Current: 15 А
- Collector Emitter Voltage Vces: 2.5 В
- Power Dissipation Max: 50 Вт
- Collector Emitter Voltage V(br)ceo: 600 В
- Рабочий диапазон температрур: -20°C ... +125°C
- Корпус транзистора: SPM32-AA
- Количество выводов: 32
- SVHC: No SVHC (18-Jun-2010)
- Тип корпуса: SPM32-AA
- Способ монтажа: Through Hole
- Тип транзистора:
- Current Ic Continuous a Max: 15 А
- Power Dissipation: 50 Вт
- Power Dissipation Pd: 50 Вт
- Pulsed Current Icm: 30 А
- Rise Time: 340 нс
- Voltage Vces: 600 В
