Datasheet Texas Instruments TPS628510 — Даташит
Серия | TPS628510 |
2.7-V to 6-V, 0.5-A, fixed-frequency, step-down converter in SOT583 package
Datasheet
Купить TPS628510 на РадиоЛоцман.Цены — от 79 до 149 ₽ 9 предложений от 5 поставщиков Микросхема: 2.7-V TO 6-V, 0.5-A, FIXED-FREQU | |||
TPS628510DRLR Texas Instruments | 79 ₽ | ||
TPS628510DRLR Texas Instruments | 99 ₽ | ||
TPS628510DRLR Texas Instruments | по запросу |
TPS628510DRLR | XPS628510DRLR | |
Статус продукта | Анонсирован | Анонсирован |
Доступность образцов у производителя | Нет | Нет |
N | 1 | 2 |
Pin | 8 | 8 |
Package Type | DRL | DRL |
Industry STD Term | SOT-5X3 | SOT-5X3 |
JEDEC Code | R-PCSO-N | R-PCSO-N |
Package QTY | 4000 | 4000 |
Carrier | LARGE T&R | LARGE T&R |
Width (мм) | 1.2 | 1.2 |
Length (мм) | 2.1 | 2.1 |
Thickness (мм) | 0.55 | 0.55 |
Pitch (мм) | 0.5 | 0.5 |
Max Height (мм) | 0.6 | 0.6 |
Parameters / Models | TPS628510DRLR | XPS628510DRLR |
Control mode | Current Mode | Current Mode |
Duty cycle(Max), % | 100 | 100 |
Основные особенности | Enable,Forced PWM,Frequency Synchronization,Light Load Efficiency,Output Discharge,Over Current Protection,Power Good,Soft Start Adjustable,Synchronous Rectification,Tracking,UVLO Adjustable | Enable,Forced PWM,Frequency Synchronization,Light Load Efficiency,Output Discharge,Over Current Protection,Power Good,Soft Start Adjustable,Synchronous Rectification,Tracking,UVLO Adjustable |
Iout, A | 0.5 | 0.5 |
Iout(Max), A | 0.5 | 0.5 |
Iq(Typ), мА | 0.015 | 15 |
Operating temperature range, C | -40 to 150 | -40 to 150 |
Package Group | SOT-5X3|8 | SOT-5X3|8 |
Package size: mm2:W x L, PKG | 8SOT-5X3: 3 mm2: 1.2 x 2.1 (SOT-5X3|8) | 8SOT-5X3: 3 mm2: 1.2 x 2.1 (SOT-5X3|8) |
Rating | Catalog | Catalog |
Regulated outputs | 1 | 1 |
Switching frequency(Max), kHz | 2475 | 2475 |
Switching frequency(Min), kHz | 2025 | 2025 |
Switching frequency(Typ), kHz | 2250 | 2250 |
Тип | Converter | Converter |
Vin(Max), В | 6 | 6 |
Vin(Min), В | 2.7 | 2.7 |
Vout(Max), В | 5.5 | 5.5 |
Vout(Min), В | 0.6 | 0.6 |
RoHS | See ti.com | See ti.com |
Серия: TPS628510 (2)
- Semiconductors > Analog and Mixed-Signal > Power management > DC/DC switching regulators > Step-down (buck) regulators > Buck converters (integrated switch)
