Datasheet Diodes PI6CG33202CZDIEX — Даташит
Производитель | Diodes |
Серия | PI6CG33202C |
Модель | PI6CG33202CZDIEX |
Very Low Power 2-OUTPUT Pcie Clock Generator With On-Chip Termination
3.3V Very Low Power 2-Output PCIe Clock Generator With On-chip Termination
Купить PI6CG33202CZDIEX на РадиоЛоцман.Цены — от 216 до 27 869 ₽ 15 предложений от 8 поставщиков Микросхема: CLOCK GENERATOR,V-QFN4040-24,T&R | |||
PI6CG33202CZDIEX-13R Diodes | 216 ₽ | ||
PI6CG33202CZDIEX Diodes | от 324 ₽ | ||
PI6CG33202CZDIEX Diodes | от 644 ₽ | ||
PI6CG33202CZDIEX Diodes | по запросу |
The PI6CG33202C is a 2-output very low power PCIe Gen1/Gen2/ Gen3/Gen4/Gen5 clock generator.
It uses 25MHz crystal or CMOS reference as an input to generate the 100MHz low power differential HCSL outputs with on-chip terminations. The on-chip termination can save 8 external resistors and make layout easier. An additional buffered reference output is provided to serve as a low noise reference for other circuitry.
It uses Diodes' proprietary PLL design to achieve very low jitter that meets PCIe Gen1/Gen2/Gen3/Gen4/Gen5 requirements.
It also provides various options such as different slew rate and amplitude through SMBUS so that users can configure the
device easily to get the optimized performance for their individual boards. The device also supports selectable spread-spectrum options to reduce EMI for various applications.
Корпус | TQFN (ZD24) MSL1 Sn |
Function | Generator |
Input Type(s) | HCSL |
Jitter | 0.05 |
Количество выходов | 2 |
Output Frequency | 100 |
Output Type(s) | HCSL |
Skew | 50 |
Напряжение питания | 3.3 |
Temperature | -40 to 85 |
- PI6CG33202CZDIEX
- Connectivity & Timing > Clock ICs > Application Specific Clocks > PCI Express (PCIe) Clock Generators
