Аналоги реле Phoenix Contact, Finder, Omron, ABB, Schneider
Datasheet Torex XCL303 — Даташит
ПроизводительTorex
СерияXCL303
Inductor Built-in Negative Output Voltage “micro DC/DC” Converters
Datasheet XCL303, XCL304
PDF, 791 Кб, Язык: анг., Файл закачен: 11 дек 2019, Страниц: 24
Электромеханические реле Hongfa – надежность и качество 19 января 2023
The XCL303 series are small coil-integrated negative voltage micro DC/DC converter IC.
The oscillating frequency is a fast 2.5MHz and the small 2.5 x 2.0 x 1.0mm package contributes significantly to space saving in PCB area.
Further, integrating the coil together with the DC/DC simplifies the circuit board layout and minimizes potential noise interference. Compared to a charge pump type solution, the switching method of the XCL303/XCL304 maintains a stable output voltage even when the input voltage fluctuates. In addition, this new micro DC/DC can support larger output current than a charge pump solution.
The PWM controlled XCL303 series can be selected for applications where low noise is important, and the PWM/PFM automatic switching controlled XCL304 series can be selected for applications where high efficiency at light load current and low noise at high load current is important.
The XCL303 series allows users to select either a PWM control or PWM/PFM automatic switching control method, which are optimum for applications where low noise and high efficiency are important.
Output voltage can be adjusted within the range of -1.2V to -6.0V using externally mounted resistors.
XCL304
Серия: XCL303 (1)
  • Inductor Built-in DC/DC Converters ("micro DC/DC")
На английском языке: Datasheet Torex XCL303
