Datasheet Texas Instruments TPS63802 — Даташит
Серия | TPS63802 |
High current, high efficiency single inductor buck-boost converter
TPS63802 2-A, high-efficient, low IQ buck-boost converter with small solution size datasheet
PDF, 2.1 Мб, Версия: A, Файл опубликован: 30 янв 2019
Купить TPS63802 на РадиоЛоцман.Цены — от 17 до 13 782 ₽ 23 предложений от 12 поставщиков Conv DC-DC 1.3V to 5.5V Synchronous Step Down/Synchronous Step Up Single-Out 1.8V to 5.2V 2A 10-Pin VSON-HR T/R | |||
TPS63802DLA Texas Instruments | 17 ₽ | ||
TPS63802DLAR Texas Instruments | 47 ₽ | ||
TPS63802DLAT Texas Instruments | по запросу | ||
TPS63802DLAR Texas Instruments | по запросу |
TPS63802DLAR | TPS63802DLAT | XPS63802DLAT | |
Статус продукта | Анонсирован | Анонсирован | В производстве |
Доступность образцов у производителя | Нет | Нет | Нет |
N | 1 | 2 | 3 |
Pin | 10 | 10 | 10 |
Package Type | DLA | DLA | DLA |
Package QTY | 3000 | 250 | 250 |
Carrier | LARGE T&R | SMALL T&R | SMALL T&R |
Маркировка | 63802 | 63802 | |
Width (мм) | 2 | 2 | 2 |
Length (мм) | 3 | 3 | 3 |
Thickness (мм) | 0.9 | 0.9 | 0.9 |
Parameters / Models | TPS63802DLAR | TPS63802DLAT | XPS63802DLAT |
Approx. price, US$ | 0.98 | 1ku | 0.98 | 1ku | 0.98 | 1ku |
Duty cycle(Max), % | 100 | 100 | 100 |
Основные особенности | Enable,Light Load Efficiency,Load Disconnect,Power Good,Pre-Bias Start-Up,Synchronous Rectification,UVLO Fixed | Enable,Light Load Efficiency,Load Disconnect,Power Good,Pre-Bias Start-Up,Synchronous Rectification,UVLO Fixed | Enable,Light Load Efficiency,Load Disconnect,Power Good,Pre-Bias Start-Up,Synchronous Rectification,UVLO Fixed |
Iout(Max), A | 2 | 2 | 2 |
Iq(Typ), мА | 0.011 | 0.011 | 0.011 |
Operating temperature range, C | -40 to 125 | -40 to 125 | -40 to 125 |
Package Group | VSON-HR|10 | VSON-HR|10 | VSON-HR|10 |
Rating | Catalog | Catalog | Catalog |
Switch current limit(Min), A | 3.9 | 3.9 | 3.9 |
Switch current limit(Typ), A | 4.5 | 4.5 | 4.5 |
Switching frequency(Max), kHz | 2500 | 2500 | 2500 |
Switching frequency(Min), kHz | 2500 | 2500 | 2500 |
Topology | Buck-Boost,Buck/Boost | Buck-Boost,Buck/Boost | Buck-Boost,Buck/Boost |
Тип | Converter | Converter | Converter |
Vin(Max), В | 5.5 | 5.5 | 5.5 |
Vin(Min), В | 1.3 | 1.3 | 1.3 |
Vout(Max), В | 5 | 5 | 5 |
Vout(Min), В | 1.8 | 1.8 | 1.8 |
RoHS | Совместим | Совместим | See ti.com |
Бессвинцовая технология (Pb Free) | Да | Да |
- Selecting a DC/DC Converter for Maximum Battery Life in Pulsed-Load ApplicationsPDF, 155 Кб, Файл опубликован: 28 ноя 2018
When designing a battery powered system maximizing batterylife is one of the most important design goals. Battery powered systems such as smart meters IoT sensors or ireless medical equipment often require a power converter to obtain fixed supply voltages for time varying loads - Prevent Battery Overdischarge with Precise Threshold Enable PinPDF, 78 Кб, Файл опубликован: 2 апр 2019
Using a buck-boost converter is a convenient way to obtain a fixed supply voltage within the wide voltage range of typical batteries used in low-power devices such as smart meters wearables or those in the Internet of Things. - Selecting the right DC/DC converter for maximum battery lifePDF, 72 Кб, Файл опубликован: 8 фев 2019
Choosing the best topology for a battery powered application such as IoT sensor smart lock or IP camera might not always be straightforward based on the available and required voltages alone. - Using Non-Inverting Buck-Boost Converter for Voltage StabilizationPDF, 734 Кб, Файл опубликован: 1 авг 2019
- Supercapacitor backup power supply with TPS63802PDF, 665 Кб, Файл опубликован: 21 янв 2019
- Precise Delayed Start-up with Precise Threshold Enable-pinPDF, 188 Кб, Файл опубликован: 15 апр 2019
- Buck-boost Converter Battery Life Time Estimation for Wireless Network Cameras (Rev. A)PDF, 123 Кб, Версия: A, Файл опубликован: 28 май 2019
- Buck-Boost Converters Solving Power Challenges in Optical ModulesPDF, 45 Кб, Файл опубликован: 13 май 2019
- Improving Load Transient Response for Controlled LoadsPDF, 338 Кб, Файл опубликован: 12 сен 2019
- Basic Calculations of a 4 Switch Buck-Boost Power Stage (Rev. B)PDF, 400 Кб, Версия: B, Файл опубликован: 9 июл 2018
This application note gives the equations to calculate the power stage of a non-inverting buck-boost converter built with an IC with integrated switches and operating in continuous conduction mode. See the references at the end of this document if more detail is needed.
Серия: TPS63802 (3)
- Semiconductors > Analog and Mixed-Signal > Power management > DC/DC switching regulators > Buck-boost & inverting > Buck-boost, inverting & split-rail converters (integrated switch)
