Datasheet Texas Instruments TPS62800 — Даташит
Серия | TPS62800 |
1.8V-5.5V input, tiny, 1A ultra-low Iq step-down converter in 1.05 x 0.70mm chip scale package
TPS6280x 1.8-V to 5.5-V, 0.6A / 1-A, 2.3-µA IQ Step Down Converter 6-Pin, 0.35-mm Pitch WCSP Package datasheet
PDF, 3.5 Мб, Версия: E, Файл опубликован: 19 сен 2018
Купить TPS62800 на РадиоЛоцман.Цены — от 75 до 12 671 ₽ 7 предложений от 7 поставщиков TPS62801/TPS62802 DC to DC Converter and Switching Regulator Chip 0.8VDC to 1.55VDC/1.8VDC to 3.3VDC Output Evaluation Board | |||
TPS62800YKAT Texas Instruments | 75 ₽ | ||
TPS62800EVM-892 Texas Instruments | 8 044 ₽ | ||
TPS62800YKAT Texas Instruments | по запросу |
TPS62800YKAR | TPS62800YKAT | |
Статус продукта | В производстве | В производстве |
Доступность образцов у производителя | Да | Нет |
N | 1 | 2 |
Pin | 6 | 6 |
Package Type | YKA | YKA |
Industry STD Term | DSBGA | DSBGA |
JEDEC Code | R-XBGA-N | R-XBGA-N |
Package QTY | 3000 | 250 |
Carrier | LARGE T&R | SMALL T&R |
Маркировка | - | - |
Width (мм) | 0.7 | 0.7 |
Length (мм) | 1.05 | 1.05 |
Thickness (мм) | 0.4 | 0.4 |
Parameters / Models | TPS62800YKAR | TPS62800YKAT |
Approx. price, US$ | 0.55 | 1ku | 0.55 | 1ku |
Control mode | DCS-Control | DCS-Control |
Duty cycle(Max), % | 100 | 100 |
Основные особенности | Enable,Forced PWM,Light Load Efficiency,Load Disconnect,Output Discharge,Over Current Protection,Synchronous Rectification,UVLO Fixed | Enable,Forced PWM,Light Load Efficiency,Load Disconnect,Output Discharge,Over Current Protection,Synchronous Rectification,UVLO Fixed |
Iout(Max), A | 1 | 1 |
Iq(Typ), мА | 0.0023 | 0.0023 |
Operating temperature range, C | -40 to 125 | -40 to 125 |
Package Group | DSBGA|6 | DSBGA|6 |
Package size: mm2:W x L, PKG | See datasheet (DSBGA) | See datasheet (DSBGA) |
Rating | Catalog | Catalog |
Regulated outputs | 1 | 1 |
Switching frequency(Max), kHz | 4000 | 4000 |
Switching frequency(Min), kHz | 4000 | 4000 |
Switching frequency(Typ), kHz | 4000 | 4000 |
Тип | Converter | Converter |
Vin(Max), В | 5.5 | 5.5 |
Vin(Min), В | 1.8 | 1.8 |
Vout(Max), В | 0.775 | 0.775 |
Vout(Min), В | 0.4 | 0.4 |
Бессвинцовая технология (Pb Free) | Да |
- Accurately measuring efficiency of ultralow-IQ devicesPDF, 254 Кб, Файл опубликован: 22 янв 2014
- How to Measure the Control Loop of DCS-Control Devices (Rev. A)PDF, 259 Кб, Версия: A, Файл опубликован: 9 авг 2012
- High-efficiency low-ripple DCS-Control offers seamless PWM/pwr-save transitionsPDF, 605 Кб, Файл опубликован: 25 июл 2013
- Understanding frequency variation in the DCS-Control(TM) topologyPDF, 224 Кб, Файл опубликован: 30 окт 2015
- A Topical Index of TI Low Power Buck DC/DC Application NotesPDF, 69 Кб, Файл опубликован: 17 янв 2018
- Five steps to a great PCB layout for a step-down converterPDF, 162 Кб, Файл опубликован: 29 янв 2015
- Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
- Achieving a clean startup by using a DC/DC converter with a precise enable-pin tPDF, 532 Кб, Файл опубликован: 24 окт 2017
- Testing tips for applying external power to supply outputs without an input voltPDF, 110 Кб, Файл опубликован: 24 окт 2016
- Basic Calculation of a Buck Converter's Power Stage (Rev. B)PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
- Understanding 100% mode in low-power DC/DC convertersPDF, 527 Кб, Файл опубликован: 22 июн 2018
- IQ: What it is what it isn’t and how to use itPDF, 198 Кб, Файл опубликован: 17 июн 2011
- Performing Accurate PFM Mode Efficiency Measurements (Rev. A)PDF, 418 Кб, Версия: A, Файл опубликован: 11 дек 2018
Серия: TPS62800 (2)
- Semiconductors > Analog and Mixed-Signal > Power management > DC/DC switching regulators > Step-down (buck) > Buck converters (integrated switch)
