Datasheet IDT 5X2503 — Даташит
Производитель | IDT |
Серия | 5X2503 |
MicroClock Programmable Clock Generator with Embedded Crystal
Купить 5X2503 на РадиоЛоцман.Цены — от 192 до 16 501 ₽ 25 предложений от 11 поставщиков Тактовый генератор, 125МГц, 1.71В до 1.89В, 3 выхода, DFN-12 | |||
5X2503-000NDGI8 Renesas | 192 ₽ | ||
5X2503-000NDGI8 Renesas | 202 ₽ | ||
5X2503-000NDGI8 Renesas | по запросу | ||
The 5X2503 MicroClock is a programmable clock generator, and is intended for low power, consumer, wearable and smart devices.
The 5X2503 device is a 3 PLL architecture design with an embedded 26MHz crystal. Each PLL is individually programmable, allowing for up to 3 unique frequency outputs. The 5X2503 has built-in unique features such as Proactive Power Saving (PPS) to deliver better system level power management.
An internal OTP memory allows the user to store the configuration in the device without programming after power up, and then can be reprogrammed again through the I²C interface. The device has programmable VCO and PLL source selection allowing the user to do power-performance optimization based on the application requirements. A low power 32.768kHz clock is supported with only less than 2μA current consumption for system RTC reference clock needs.
5X2503-000NDGI | 5X2503-000NDGI8 | |
Статус продукта | В производстве (Рекомендуется для новых разработок) | В производстве (Рекомендуется для новых разработок) |
N | 1 | 2 |
Код корпуса производителя | NDG12 | NDG12 |
Parameters / Models | 5X2503-000NDGI | 5X2503-000NDGI8 |
Temperature Grade | I | I |
Бессвинцовая технология (Pb Free) | Да | Да |
- Clocks & Timing > Clock Generation > Programmable Clocks > MicroClock Programmable Clock Generator with Embedded Crystal
