Datasheet ABLIC S-19214 — Даташит
ПроизводительABLIC
СерияS-19214
МодельS-19214
Automotive, 125°C Operation, 36 V Input, 1000 mA Voltage Regulator
Datasheet S-19214
PDF, 812 Кб, Язык: анг., Файл закачен: 2 авг 2019, Страниц: 46
Электромеханические реле Hongfa – надежность и качество 19 января 2023
The S-19214 Series developed by using high-withstand voltage CMOS process technology, is a positive voltage regulator with a high-withstand voltage, low current consumption and high-accuracy output voltage.
The S-19214 Series operates at the maximum operation voltage of 36 V and a low current consumption of 5.0 μA typ.
and has a built-in low on-resistance output transistor, which provides a very small dropout voltage and a large output current.
In addition to the type in which output voltage is set inside the IC, the type for which output voltage can be set via an external resistor is added to a lineup. Also, a built-in overcurrent protection circuit to limit overcurrent of the output transistor and a built-in thermal shutdown circuit to limit heat are included.
  • Automotive ICs > Automotive Voltage Regulators (LDO Regulators)
S19214, S 19214
На английском языке: Datasheet ABLIC S-19214
