Datasheet Dialog Semiconductor SLG51000 — Даташит
ПроизводительDialog Semiconductor
СерияSLG51000
МодельSLG51000
High PSRR, low noise multi-output LDO CMIC for advanced camera and sensor systems
The SLG51000 CMIC contains seven compact and customizable low dropout regulators and is designed for high performance camera modules, advanced sensor systems, and other small multi-rail applications.
SLG51000 Datasheet
Features
  • Highest PSRR of 73dB at 1MHz
  • Lowest output voltage noise of 10µV (rms)
  • 7 channels of LDOs
  • Output current capability up to 800mA per channel
  • User configurable settings via I2C and OTP including output voltage, sequencing, soft-start timing, and current limit threshold
  • 6 user-defined GPIOs to route available internal and external signals
  • Flexible user-defined supply controller with matrix interconnect logic, GPIOs, and macrocells
  • Small 20-pin 1.675mm x 2.075mm 0.465mm WLCSP package
  • Power Management > CMIC Imaging and Sensing
На английском языке: Datasheet Dialog Semiconductor SLG51000
