Datasheet Diodes PI3EQX16904GL — Даташит
Производитель | Diodes |
Серия | PI3EQX16904GL |
4 Channel Pcie 4.0 Redriver With Linear Type
Купить PI3EQX16904GLZHEX на РадиоЛоцман.Цены — от 336 до 1 024 ₽ 13 предложений от 6 поставщиков Микросхема: PCIE EQX V-QFN3590-42 | |||
PI3EQX16904GLZHEX Diodes | 336 ₽ | ||
PI3EQX16904GLZHEX Diodes | 343 ₽ | ||
PI3EQX16904GLZHEX Diodes | от 685 ₽ | ||
PI3EQX16904GLZHEX Diodes | по запросу |
Diodes’ PI3EQX16904GL is a multi-data rate, 4 differential channels ReDriver™.
The device provides programmable linear equalization, output swing and flat gain, by either pin strapping option or I2C Control, to optimize performance over a variety of physical mediums by reducing Inter-symbol interference.
PI3EQX16904GL supports four 100-Ohm Differential CML data I/O’s and extends the signals across other distant data pathways on the user’s platform.
The integrated equalization circuitry provides flexibility with signal integrity of the signal before the ReDriver, whereas the integrated linear amplifier/buffer circuitry provides flexibility with signal integrity of the signal after the ReDriver.
PI3EQX16904GLZHEX | |
N | 1 |
Корпус | TQFN (ZH42) MSL1 PPF |
Parameters / Models | PI3EQX16904GLZHEX |
Data Rate (Gbps) | 16 |
Lanes/Ports | 4 |
Количество каналов | 4 |
Output Swing Max (mV) | Pin strap, I2C master/Salve |
Programming Interface(s) | Pin strap, I2C master/Salve |
- Connectivity & Timing > Signal Integrity - ReDrivers/Repeaters/Signal Conditioners
