Datasheet Wago 885 — Даташит
Производитель | Wago |
Серия | 885 |
Купить 885-106 на РадиоЛоцман.Цены — от 170 до 5 081 ₽ 1x болтовая клемма, 2,5 - 35 мм2, M6 | |||
885-106 Wago | 170 ₽ | ||
885-106 Wago Оф. дистрибьютор | 1 926 ₽ | ||
885-106 Wago | 5 081 ₽ |
Parameters / Models | 885-106 | 885-108 | 885-110 | 885-112 | 885-306 | 885-308 | 885-310 | 885-406 | 885-408 | 885-410 | 885-412 | 885-426 | 885-428 | 885-430 | 885-432 | 885-448 | 885-470 | 885-506 | 885-508 | 885-510 | 885-526 | 885-528 | 885-530 | 885-546 | 885-548 | 885-550 | 885-566 | 885-570 | 885-580 |
Actuation type | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | ||||||||||||||||||||||
Цвет | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | transparent | transparent | gray | ||||||||||
Connectable conductor materials | Copper | Copper | Copper | Copper | Copper | Copper | Copper | ||||||||||||||||||||||
Connection technology | Screw-clamp connection/Studs | Screw-clamp connection/Studs | Screw-clamp connection/Studs | Screw-clamp connection/Studs | Screw-clamp connection/Studs | Screw-clamp connection/Studs | Screw-clamp connection/Studs | ||||||||||||||||||||||
Country of origin | CN | CN | CN | CN | CN | CN | CN | CN | CN | CN | CN | CN | CN | CN | CN | DE | DE | CN | CN | CN | CN | CN | CN | CN | CN | CN | DE | DE | DE |
Габариты: глубина | 67 mm / 2.638 inch | 67 mm / 2.638 inch | 67 mm / 2.638 inch | 67 mm / 2.638 inch | 67 mm / 2.638 inch | 67 mm / 2.638 inch | 67 mm / 2.638 inch | 15 mm / 0.591 inch | 20 mm / 0.787 inch | 25 mm / 0.984 inch | 25 mm / 0.984 inch | 15 mm / 0.591 inch | 20 mm / 0.787 inch | 25 mm / 0.984 inch | 25 mm / 0.984 inch | 20 mm / 0.787 inch | 25 mm / 0.984 inch | 67 mm / 2.638 inch | 67 mm / 2.638 inch | 67 mm / 2.638 inch | 102.3 mm / 4.028 inch | 110.3 mm / 4.343 inch | 157 mm / 6.181 inch | 102.3 mm / 4.028 inch | 110.3 mm / 4.343 inch | 157 mm / 6.181 inch | 33.3 mm / 1.311 inch | 51.3 mm / 2.02 inch | |
Fire load, MJ | 0.39 | 0.537 | 0.831 | 0.377 | 0.537 | 0.831 | 0.375 | 0.492 | 0.728 | 0.336 | 0.398 | 0.684 | 0.294 | 0.36 | 0.603 | 3.45 | 0.006 | ||||||||||||
GTIN | 4050821049227 | 4050821049234 | 4050821049241 | 4050821092087 | 4050821049258 | 4050821049265 | 4050821049272 | 4050821049289 | 4050821049371 | 4050821049388 | 4050821092094 | 4050821049395 | 4050821049401 | 4050821049418 | 4050821092100 | 4050821049425 | 4050821049432 | 4050821049296 | 4050821049302 | 4050821049319 | 4050821092032 | 4050821092049 | 4050821049333 | 4050821092056 | 4050821092063 | 4050821049340 | 4050821092070 | 4050821049357 | 4050821049364 |
Height | 4 mm / 0.157 inch | 4 mm / 0.157 inch | 4 mm / 0.157 inch | 4 mm / 0.157 inch | 4 mm / 0.157 inch | 4 mm / 0.157 inch | 4 mm / 0.157 inch | 4 mm / 0.157 inch | 4 mm / 0.157 inch | 4 mm / 0.157 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 58.8 mm / 2.315 inch | 67.2 mm / 2.646 inch | 76.8 mm / 3.024 inch | 58.8 mm / 2.315 inch | 67.2 mm / 2.646 inch | 76.8 mm / 3.024 inch | 5.8 mm / 0.228 inch | 5.8 mm / 0.228 inch | ||||||||
Height from upper-edge of DIN-35 rail | 48.7 mm / 1.917 inch | 56.7 mm / 2.232 inch | 66.7 mm / 2.626 inch | 64.7 mm / 2.547 inch | 48.7 mm / 1.917 inch | 56.7 mm / 2.232 inch | 66.7 mm / 2.626 inch | 26.5 mm / 1.043 inch | 26.5 mm / 1.043 inch | 26.5 mm / 1.043 inch | |||||||||||||||||||
Legend (ratings) | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | ||||||||||||||||||||||
Marking level | Side marking | Side marking | Side marking | Side marking | Side marking | Side marking | Side marking | ||||||||||||||||||||||
Packaging type | bag | bag | bag | bag | bag | bag | bag | bag | bag | bag | |||||||||||||||||||
Product Group | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) |
Rated current, A | 125 | 150 | 269 | 269 | 125 | 150 | 269 | ||||||||||||||||||||||
Rated impulse voltage (III / 3), kV | 8 | 8 | 8 | 8 | 8 | 8 | 8 | ||||||||||||||||||||||
Rated voltage (III / 3), В | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | ||||||||||||||||||||||
Solid conductor | 2.5 … 35 mm² / 14 … 2 AWG | 2.5 … 50 mm² / 14 … 1/0 AWG | 6 … 120 mm² / 10 AWG … 250 kcmil | 6 … 120 mm² / 10 AWG … 250 kcmil | 2.5 … 35 mm² / 14 … 2 AWG | 2.5 … 50 mm² / 14 … 1/0 AWG | 6 … 120 mm² / 10 AWG … 250 kcmil | ||||||||||||||||||||||
Tightening torque | 3 … 6 Nm | 6 … 12 Nm | 10 … 20 Nm | 10 … 20 Nm | 3 … 6 Nm | 6 … 12 Nm | 10 … 20 Nm | ||||||||||||||||||||||
Total number of connection points | 1 | 1 | 1 | 1 | 3 | 3 | 3 | ||||||||||||||||||||||
Total number of potentials | 1 | 1 | 1 | 1 | 1 | 1 | 1 | ||||||||||||||||||||||
Type of mounting | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | ||||||||||||||||||||||
Type of wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | ||||||||||||||||||||||
Вес, г | 27.4 | 46.76 | 88.216 | 115.113 | 66.606 | 121.8 | 228.166 | 13.4 | 24.7 | 42.4 | 39.4 | 22.4 | 39 | 69.5 | 65.5 | 19.75 | 30 | 13.343 | 17.886 | 25.986 | 11.2 | 13.7 | 22.8 | 9.8 | 12 | 20.1 | 53.5 | 700 | 0.19 |
Ширина | 17.8 mm / 0.701 inch | 22.8 mm / 0.898 inch | 33.8 mm / 1.331 inch | 33.8 mm / 1.331 inch | 17.8 mm / 0.701 inch | 22.8 mm / 0.898 inch | 33.8 mm / 1.331 inch | 30.2 mm / 1.189 inch | 40.2 mm / 1.583 inch | 54.2 mm / 2.134 inch | 54.2 mm / 2.134 inch | 48 mm / 1.89 inch | 63 mm / 2.48 inch | 88 mm / 3.465 inch | 88 mm / 3.465 inch | 35.2 mm / 1.386 inch | 42.2 mm / 1.661 inch | 17.8 mm / 0.701 inch | 22.8 mm / 0.898 inch | 33.8 mm / 1.331 inch | 2 mm / 0.079 inch | 2 mm / 0.079 inch | 2 mm / 0.079 inch | 2 mm / 0.079 inch | 2 mm / 0.079 inch | 2 mm / 0.079 inch | 1000 mm / 39.37 inch | 1000 mm / 39.37 inch |
Серия: 885 (29)
