Datasheet Texas Instruments ADS7834P — Даташит
Серия | ADS7834 |
Модель | ADS7834P |
12-битный высокоскоростной аналого-цифровой преобразователь с низким энергопотреблением и дискретизацией 8-PDIP
12-Bit High Speed, Low Power Sampling Analog-to-Digital Converter datasheet
PDF, 894 Кб, Версия: A, Файл опубликован: 15 сен 2003
Купить ADS7834P на РадиоЛоцман.Цены — от 254 до 17 308 ₽ 6 предложений от 6 поставщиков | |||
ADS7834P Texas Instruments | 254 ₽ | ||
ADS7834P Texas Instruments | по запросу | ||
Pin | 8 |
Package Type | P |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Width (мм) | 6.35 |
Length (мм) | 9.81 |
Thickness (мм) | 3.9 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
# Input Channels | 1 |
Analog Voltage AVDD(Max)(V) | 5.25 |
Analog Voltage AVDD(Min)(V) | 4.75 |
Approx. Price (US$) | 2.57 | 1ku |
Архитектура | SAR |
Digital Supply(Max)(V) | 5.25 |
Digital Supply(Min)(V) | 4.75 |
INL(Max)(+/-LSB) | 1 |
Input Range(Max)(V) | 2.5 |
Тип входа | Pseudo-Differential Single-Ended |
Integrated Features | N/A |
Interface | Serial SPI |
Multi-Channel Configuration | N/A |
Operating Temperature Range(C) | -40 to 85 |
Package Group | VSSOP |
Package Size: mm2:W x L (PKG) | See datasheet (PDIP) |
Power Consumption(Typ)(mW) | 11 |
Rating | Catalog |
Reference Mode | Ext Int |
Resolution(Bits) | 12 |
SINAD(dB) | 70 |
SNR(dB) | 72 |
Sample Rate (max)(SPS) | 500kSPS |
THD(Typ)(dB) | -78 |
RoHS | Не совместим |
- Interfacing the MSOP8EVM to TMS470 ProcessorsPDF, 68 Кб, Файл опубликован: 15 мар 2006
This application report presents a method for interfacing the modular MSOP8EVM, an evaluation module (EVM) for single-channel, low-power, 8- to 16-bit serial analog-to-digital converters to the TMS470 series microcontrollers. The hardware used for this example includes the TMS470 Kickstart Development Kit evaluation kit featuring the 60-MHz TMS470R1B1M and the HPA-MCU Interface Board. The soft - Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
The input structure circuit of a successive-approximation register analog-to-digital converter (SAR ADC) incombination with the driving circuit forms a transfer function that can be used to determine minimum acquisition times for different types of applied input signals. This application report, which builds on Determining Minimum Acquisition Times for SAR ADCs When a Step Function is Applied to - Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Interleaving Analog-to-Digital ConvertersPDF, 64 Кб, Файл опубликован: 2 окт 2000
It is tempting when pushing the limits of analog-to-digital conversion to consider interleaving two or more converters to increase the sample rate. However, such designs must take into consideration several possible sources of error. - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
- What Designers Should Know About Data Converter DriftPDF, 95 Кб, Файл опубликован: 2 окт 2000
Exactly how inaccurate will a change in temperature make an analog-to-digital or digital-to-analog converter? As designers are well aware, a 12-bit device may provide a much lower accuracy at its operating-temperature extremes, perhaps only to 9 or even 8 bits. But for lack of more precise knowledge, many play it safe (and expensive) and overspecify.
Серия: ADS7834 (10)
- Semiconductors > Data Converters > Analog to Digital Converter > Precision ADC (<=10MSPS)
