Datasheet Intersil EL7535IY-T7 — Даташит
Monolithic 350mA Step-Down Regulator
EL7535 Datasheet
PDF, 511 Кб, Версия: 2017-10-17, Файл закачен: 9 май 2018
Купить EL7535IY-T7 на РадиоЛоцман.Цены — от 47 до 152 ₽ 13 предложений от 7 поставщиков Buck Switching Regulator IC Positive Adjustable 0.8V 1 Output 350mA 10-TFSOP, 10-MSOP (0.118, 3.00mm Width) | |||
EL7535IY-T7 | от 47 ₽ | ||
EL7535IY-T7 | от 48 ₽ | ||
EL7535IY-T7 Intersil | по запросу | ||
EL7535IY-T7 | по запросу |
Корпус | 10 Ld MSOP T+R |
Индекс корпуса | M10.118A |
Пиковая температура пайки | 240°C |
# of Outputs | 1 |
Control Type | Voltage Mode |
Description | Monolithic 350mA Step-Down Regulator |
IOUT (max) (A) | 0.35 |
Max Duty Cycle (%) | See Datasheet |
POR | Yes |
Peak Efficiency (%) | 94 |
Switching Freq. (max) | 1.5 MHz |
Switching Freq. (min) | 1.5 MHz |
Topology | Buck |
VIN (max) (V) | 5.5 |
VIN (min) (V) | 2.5 |
VOUT (max) (V) | 5.5 |
VOUT (min) (V) | 0.8 |
Серия: EL7535 (6)
- EL7535IY EL7535IY-T13 EL7535IY-T7 EL7535IYZ EL7535IYZ-T13 EL7535IYZ-T7
- Power Management > Switching Regulators > Integrated FET Regulators
EL7535IYT7, EL7535IY T7
