Datasheet Intersil ISL9104 — Даташит
Производитель | Intersil |
Серия | ISL9104 |
500mA 4.3MHz Low IQ High Efficiency Synchronous Buck Converter
ISL9104, ISL9104A Datasheet
PDF, 742 Кб, Версия: 2017-10-26, Файл закачен: 9 май 2018
Купить ISL9104 на РадиоЛоцман.Цены — от 57 до 82 ₽ 23 предложений от 17 поставщиков Buck Switching Regulator IC Positive Adjustable 0.8V 1 Output 500mA 6-UFDFN | |||
ISL9104IRUDZ-T Intersil | 57 ₽ | ||
ISL9104IRUBZ-T Intersil | 61 ₽ | ||
ISL9104IRUCZ-T Intersil | по запросу | ||
ISL9104IRUAZ-T | по запросу |
Parameters / Models | ISL9104IRUAZ-T | ISL9104IRUAZ-T7A | ISL9104IRUBZ-T | ISL9104IRUBZ-T7A | ISL9104IRUCZ-T | ISL9104IRUCZ-T7A | ISL9104IRUDZ-T | ISL9104IRUDZ-T7A | ISL9104IRUFZ-T | ISL9104IRUFZ-T7A | ISL9104IRUJZ-T | ISL9104IRUJZ-T7A | ISL9104IRUNZ-T | ISL9104IRUNZ-T7A | ISL9104IRUWZ-T | ISL9104IRUWZ-T7A |
# of Outputs | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
BOM Total Footprint | 322.6 mm2 | 322.6 mm2 | 322.6 mm2 | 322.6 mm2 | 322.6 mm2 | 322.6 mm2 | 322.6 mm2 | 322.6 mm2 | 322.6 mm2 | 322.6 mm2 | 322.6 mm2 | 322.6 mm2 | 322.6 mm2 | 322.6 mm2 | 322.6 mm2 | 322.6 mm2 |
Control Type | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode |
Description | 500mA 4.3MHz Low IQ High Efficiency Synchronous Buck Converter | 500mA 4.3MHz Low IQ High Efficiency Synchronous Buck Converter | 500mA 4.3MHz Low IQ High Efficiency Synchronous Buck Converter | 500mA 4.3MHz Low IQ High Efficiency Synchronous Buck Converter | 500mA 4.3MHz Low IQ High Efficiency Synchronous Buck Converter | 500mA 4.3MHz Low IQ High Efficiency Synchronous Buck Converter | 500mA 4.3MHz Low IQ High Efficiency Synchronous Buck Converter | 500mA 4.3MHz Low IQ High Efficiency Synchronous Buck Converter | 500mA 4.3MHz Low IQ High Efficiency Synchronous Buck Converter | 500mA 4.3MHz Low IQ High Efficiency Synchronous Buck Converter | 500mA 4.3MHz Low IQ High Efficiency Synchronous Buck Converter | 500mA 4.3MHz Low IQ High Efficiency Synchronous Buck Converter | 500mA 4.3MHz Low IQ High Efficiency Synchronous Buck Converter | 500mA 4.3MHz Low IQ High Efficiency Synchronous Buck Converter | 500mA 4.3MHz Low IQ High Efficiency Synchronous Buck Converter | 500mA 4.3MHz Low IQ High Efficiency Synchronous Buck Converter |
IOUT (max) (A) | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 |
IQ | 20 µA | 20 µA | 20 µA | 20 µA | 20 µA | 20 µA | 20 µA | 20 µA | 20 µA | 20 µA | 20 µA | 20 µA | 20 µA | 20 µA | 20 µA | 20 µA |
Max Duty Cycle (%) | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
POR | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
Peak Efficiency (%) | 93 | 93 | 93 | 93 | 93 | 93 | 93 | 93 | 93 | 93 | 93 | 93 | 93 | 93 | 93 | 93 |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
SYNCH Capability | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
Switching Freq. (max) | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz |
Switching Freq. (min) | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz | 4.3 MHz |
Topology | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck |
VIN (max) (V) | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 |
VIN (min) (V) | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
VOUT (max) (V) | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 |
VOUT (min) (V) | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
ISL9104IRUAZ-T | ISL9104IRUAZ-T7A | ISL9104IRUBZ-T | ISL9104IRUBZ-T7A | ISL9104IRUCZ-T | ISL9104IRUCZ-T7A | ISL9104IRUDZ-T | ISL9104IRUDZ-T7A | ISL9104IRUFZ-T | ISL9104IRUFZ-T7A | ISL9104IRUJZ-T | ISL9104IRUJZ-T7A | ISL9104IRUNZ-T | ISL9104IRUNZ-T7A | ISL9104IRUWZ-T | ISL9104IRUWZ-T7A | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ISL9104 (16)
- Power Management > Switching Regulators > Integrated FET Regulators
