Datasheet Texas Instruments TPS65381AQDAPRQ1 — Даташит
Серия | TPS65381A-Q1 |
Модель | TPS65381AQDAPRQ1 |
Multi-Rail Power Supply (PMIC) for Microcontrollers in Safety Applications 32-HTSSOP -40 to 125
TPS65381A-Q1 Multirail Power Supply for Microcontrollers in Safety-Relevant Applications datasheet
PDF, 1.6 Мб, Версия: A, Файл опубликован: 1 май 2017
Купить TPS65381AQDAPRQ1 на РадиоЛоцман.Цены — от 164 до 1 816 ₽ 17 предложений от 10 поставщиков Automotive, AEC-Q100, Functional Safety (FuSa) Automotive, Industrial Safety Voltage Regulator IC 5 Output 32-HTSSOP | |||
TPS65381AQDAPRQ1 Texas Instruments | от 164 ₽ | ||
TPS65381AQDAPRQ1 Texas Instruments | 288 ₽ | ||
TPS65381AQDAPRQ1 Texas Instruments | 1 689 ₽ | ||
TPS65381AQDAPRQ1 Texas Instruments | по запросу |
Pin | 32 |
Package Type | DAP |
Industry STD Term | HTSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Width (мм) | 6.2 |
Length (мм) | 11 |
Thickness (мм) | 1.15 |
Pitch (мм) | 0.65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Основные особенности | Comm Control,Power Good,Thermal Shutdown,UVLO Fixed |
Iout(Max) | 1.3 A |
Iq(Typ) | 0.075 мА |
LDO | 4 |
Package Group | HTSSOP |
Package Size: mm2:W x L | 32HTSSOP: 89 mm2: 8.1 x 11(HTSSOP) PKG |
Processor Name | TMS570 |
Processor Supplier | Texas Instruments |
Rating | Automotive |
Regulated Outputs | 5 |
Step-Down DC/DC Converter | 1 |
Switching Frequency(Max) | 440 kHz |
Vin(Max) | 40 В |
Vin(Min) | 4.5 В |
Vout(Max) | 9.5 В |
Vout(Min) | 0.8 В |
- Evaluation Modules & Boards: TPS65381EVM
TPS65381EVM - EVM for Multi-Rail Power Supply for Microcontrollers in Safety-Critical Applications
- Safety Manual for TPS65381-Q1 and TPS65381A-Q1 Multirail Power Supply (Rev. C)PDF, 347 Кб, Версия: C, Файл опубликован: 5 янв 2018
This document is a safety manual for the Texas Instruments TPS65381x-Q1 (TPS65381-Q1 and TPS65381A-Q1) multirail power supply. This manual provides information to help developers integrate the TPS65381x-Q1 device into safety related systems. - Device Behavior Under Slow VBAT Ramp-Down and Ramp-UpPDF, 117 Кб, Файл опубликован: 23 янв 2015
This application report explains device behavior under slow battery-supply voltage ramp-up and ramp-downconditions based on device supply-rail configuration. Laboratory test results and device simulationsresults are included to support the analysis and device behavior. - TPS65381-Q1 and TPS65381A-Q1 Design Checklist (Rev. A)PDF, 73 Кб, Версия: A, Файл опубликован: 5 апр 2017
This checklist is provided as an aid for customers of Texas Instruments related to their use of the TPS65381-Q1 and TPS65381A-Q1 (TPS65381x-Q1) device. - DPI Evaluation TPS65381-Q1PDF, 503 Кб, Файл опубликован: 28 фев 2013
The TPS65381 is a multi-rail power supply designed to supply microcontrollers in safety criticalapplications such as those found in automotive. The devices supports Texas Instruments TMS570LSseries 16/32-Bit RISC Flash MCU and other microcontrollers with dual-core lockstep (LS) or loosely coupled architectures (LC). - Efficiency Evaluation TPS65381-Q1PDF, 37 Кб, Файл опубликован: 29 авг 2013
The TPS65381 is a multi-rail power supply designed to supply microcontrollers in safety critical applications such as those found in automotive functions. The device supports Texas Instruments' TMS570LS series 16/32-Bit RISC Flash MCU and other microcontrollers with dual-core lockstep (LS) or loosely coupled (LC) architectures.The TPS65381 integrates multiple supply rails to power the MCU CA
Серия: TPS65381A-Q1 (2)
- TPS65381AQDAPRQ1 TPS65381AQDAPTQ1
- Semiconductors > Power Management > Power Management Multi-Channel IC (PMIC) Solutions
