Datasheet Texas Instruments TPS65154RSLR — Даташит
Серия | TPS65154 |
Модель | TPS65154RSLR |
LCD Bias IC with Integrated WLED Driver 48-VQFN -40 to 85
TPS65154 LCD Bias IC with Integrated WLED Driver datasheet
PDF, 2.7 Мб, Версия: A, Файл опубликован: 30 июн 2016
Купить TPS65154RSLR на РадиоЛоцман.Цены — от 138 до 381 ₽ 9 предложений от 9 поставщиков Portable Equipment PMIC 48-VQFN (6x6) | |||
TPS65154RSLR Texas Instruments | 138 ₽ | ||
TPS65154RSLR Texas Instruments | 177 ₽ | ||
TPS65154RSLR Texas Instruments | по запросу | ||
Pin | 48 |
Package Type | RSL |
Industry STD Term | VQFN |
JEDEC Code | S-PQFP-N |
Package QTY | 2500 |
Carrier | LARGE T&R |
Width (мм) | 6 |
Length (мм) | 6 |
Thickness (мм) | 0.9 |
Pitch (мм) | 0.4 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
DisplayType | LCD Unipolar |
IC Integration | LCD Bias,LED Backlight,VCOM |
Pin/Package | 48VQFN |
Source Driver Voltage(Max) | 9.6 В |
Source Driver Voltage(Min) | 6.5 В |
Special Function | Adjustable Sequencing,Backlight Driver,GPM/GVS,I2C I/F,Output Discharge,Reset Generator,VCOM/OpAmp |
Target Application | 13 to 21 inches,7 to 13 inches |
Vin(Max) | 5.5 В |
Vin(Min) | 2 В |
- Understanding Undervoltage Lockout in Power Devices (Rev. A)PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products. - Basic Calculation of a Boost Converter's Power Stage (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS65154 (1)
- TPS65154RSLR
- Semiconductors > Power Management > LCD/OLED Display Bias Solutions
