Datasheet Texas Instruments TPS24771RGET — Даташит
Серия | TPS24771 |
Модель | TPS24771RGET |
2,5–18 В Высокопроизводительный контроллер с возможностью горячей замены 24-VQFN -40–125
TPS2477x 2.5 to 18-V High Performance Hot Swap datasheet
PDF, 2.2 Мб, Файл опубликован: 3 мар 2015
Купить TPS24771RGET на РадиоЛоцман.Цены — от 171 до 415 ₽ 25 предложений от 12 поставщиков TEXAS INSTRUMENTS TPS24771RGET Hot-Swap Controller, 2.5V to 18V supply, VQFN-24 | |||
TPS24771RGET Texas Instruments | 171 ₽ | ||
TPS24771RGET Texas Instruments | от 172 ₽ | ||
TPS24771RGET Texas Instruments | 192 ₽ | ||
TPS24771RGET Texas Instruments | 235 ₽ |
Pin | 24 | 24 |
Package Type | RGE | RGE |
Industry STD Term | VQFN | VQFN |
JEDEC Code | S-PQFP-N | S-PQFP-N |
Package QTY | 250 | 250 |
Carrier | SMALL T&R | SMALL T&R |
Маркировка | 24771 | TPS |
Width (мм) | 4 | 4 |
Length (мм) | 4 | 4 |
Thickness (мм) | .88 | .88 |
Pitch (мм) | .5 | .5 |
Max Height (мм) | 1 | 1 |
Channel(s) Controlled | 1 |
Current Limit Accuracy | Adjustable |
Current Limit Function Enabled | Startup Only |
Current Limit Threshold(Typ) | Adjustable Ext FET=mV |
Current Measurement Accuracy | Adjustable % |
Design Support | Calculation Tool,EVM,Reference Design,Simulation Model |
FET Protection | SOA |
Fault Response | Auto Retry |
ON_OFF Control Input | EN s |
Package Group | VQFN |
Package Size: mm2:W x L | 24VQFN: 16 mm2: 4 x 4(VQFN) PKG |
Rating | Catalog |
Special Features | Analog IMON Output |
Status Output | FLT,PG |
Vabsmax_cont | 30 В |
Vin(Max) | 18 В |
Vin(Min) | 2.5 В |
- Evaluation Modules & Boards: TPS24772EVM-685
TPS24772 EVM for high performance hotswap applications
Серия: TPS24771 (2)
- TPS24771RGER TPS24771RGET
- Semiconductors > Power Management > Protection, Monitoring and Hot Swap > Hot Swap Controllers (Positive, -48V)
