Datasheet Texas Instruments LM5145RGYT — Даташит
Серия | LM5145 |
Модель | LM5145RGYT |
75V Synchronous Buck Controller With Wide Input Voltage and Duty Cycle Ranges 20-VQFN -40 to 125
LM5145 6-V to 75-V Synchronous Buck DC-DC Controller With Wide Duty Cycle Range datasheet
PDF, 2.3 Мб, Файл опубликован: 7 июн 2016
Купить LM5145RGYT на РадиоЛоцман.Цены — от 782 до 8 476 ₽ 10 предложений от 6 поставщиков Buck Regulator Positive Output Step-Down DC-DC Controller IC 20-VQFN (3.5x4.5) | |||
LM5145RGYT Texas Instruments | от 782 ₽ | ||
LM5145RGYT Texas Instruments | 8 294 ₽ | ||
LM5145RGYT Texas Instruments | 8 476 ₽ | ||
LM5145RGYT Texas Instruments | по запросу |
Pin | 20 |
Package Type | RGY |
Industry STD Term | VQFN |
JEDEC Code | R-PQFP-N |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | LM5145 |
Width (мм) | 3.5 |
Length (мм) | 4.5 |
Thickness (мм) | .9 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Control Mode | Voltage Mode |
Duty Cycle(Max) | 99 % |
Iout(Max) | 30 A |
Iq(Typ) | 1.5 мА |
Number of Phases | 1 |
Package Group | VQFN |
Rating | Catalog |
Regulated Outputs | 1 |
Special Features | Adjustable Current Limit,Enable,Frequency Synchronization,Light Load Efficiency,Power Good,Pre-Bias Start-Up,Synchronous Rectification,Tracking,UVLO Adjustable |
Switching Frequency(Max) | 1000 kHz |
Switching Frequency(Min) | 100 kHz |
Тип | Controller |
Vin(Max) | 75 В |
Vin(Min) | 6 В |
Vout(Max) | 60 В |
Vout(Min) | 0.8 В |
- Evaluation Modules & Boards: LM5145EVM-HD-20A
LM5145 Wide VIN Synchronous Buck Controller High Density Evaluation Module
- Reduce buck-converter EMI and voltage stress by minimizing inductive parasiticsPDF, 926 Кб, Файл опубликован: 21 июл 2016
Серия: LM5145 (2)
- LM5145RGYR LM5145RGYT
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
