Datasheet Microchip ATTINY404 — Даташит
Производитель | Microchip |
Серия | ATTINY404 |
The ATtiny404 is a microcontroller using the 8-bit AVR® processor with hardware multiplier, running at up to 20MHz and 4KB Flash, 256B SRAM and 128 bytes of EEPROM in a 14-pin package
ATtiny204/404 Preliminary Data Sheet
PDF, 3.7 Мб, Файл опубликован: 19 мар 2018
Купить ATTINY404 на РадиоЛоцман.Цены — от 45 до 3 906 ₽ 27 предложений от 13 поставщиков AVR tinyAVRTM0, Functional Safety (FuSa) Microcontroller IC 8-Bit 20MHz 4KB (4K x 8) FLASH 14-SOIC | |||
ATTINY404-SSF Microchip | 45 ₽ | ||
ATTINY404-SSF Microchip | 46 ₽ | ||
ATTINY404-SSFR Microchip | от 119 ₽ | ||
ATTINY404-SSNR Microchip | по запросу |
ATTINY404-SSFR | ATTINY404-SSNR | |
N | 1 | 2 |
Корпус | SOIC | SOIC |
Parameters / Models | ATTINY404-SSFR | ATTINY404-SSNR |
ADC Input | 12 | 12 |
ADC with Computation | No | No |
Angular Timer | No | No |
Архитектура | 8 | 8 |
CPU Type | 8-bit AVR | 8-bit AVR |
CRC | Yes | Yes |
Class B Hardware | Yes | Yes |
Configurable Logic Cell, CLC/CCL | 1 | 1 |
Emulated EEPROM in Flash | 128 / HEF | 128 / HEF |
High Voltage Capable | No | No |
I2C | 1 | 1 |
Internal Oscillator | 20 MHz, 32 kHz | 20 MHz, 32 kHz |
Internal Voltage Reference, Bandgap | Yes | Yes |
Lead Count | 14 | 14 |
Math Accelerator | No | No |
Max 16-Bit Digital Timers | 2 | 2 |
Max ADC Resolution, Bits | 10 | 10 |
Max CPU Speed, МГц | 20 | 20 |
Количество компараторов | 1 | 1 |
Operation Voltage Max, В | 5.5 | 5.5 |
Operation Voltage Min, В | 1.8 | 1.8 |
PWM Max Resolution, Bits | 8 | 8 |
Package Width | .150In(3.90mm) | .150In(3.90mm) |
Peripheral Pin Select / Pin Muxing | Yes | Yes |
Pin count | 14 | 14 |
Размер памяти программ, KB | 4 | 4 |
SPI | 1 | 1 |
SRAM, Bytes | 256 | 256 |
Temp Range Max | 125 | 125 |
Temp Range Min | -40 | -40 |
UART | 1 | 1 |
Zero Cross detect | No | No |
Серия: ATTINY404 (2)
- Microcontrollers > 8-bit Microcontrollers
