Datasheet Intersil ISL78845ASRH — Даташит
ПроизводительIntersil
СерияISL78845ASRH
Radiation Hardened, High Performance Industry Standard Single-Ended Current Mode PWM Controller
ISL78840ASEH, ISL78841ASEH, ISL78843ASEH, ISL78845ASEH Datasheet
PDF, 885 Кб, Версия: 2017-11-07
Radiation Hardened, High Performance IndustryStandard Single-Ended Current Mode PWM Controller
LifeElectronics
ISL78845ASRH
Intersil
Электромеханические реле Hongfa – надежность и качество 19 января 2023
ISL78845ASRHD/PROTOISL78845ASRHF/PROTOISL78845ASRHQDISL78845ASRHQFISL78845ASRHVDISL78845ASRHVFISL78845ASRHVX
N1234567
Intersil D8.3Intersil K8.AIntersil D8.3Intersil K8.AIntersil D8.3Intersil K8.A
Корпус8 Ld SBDIP
Габаритный чертеж корпуса
8 Ld CFP
8 Ld SBDIP
8 Ld CFP
8 Ld SBDIP
8 Ld CFP
Индекс корпусаD8.3K8.AD8.3K8.AD8.3K8.A
Количество выводов888888
СемействоSBDIPCFPSBDIPCFPSBDIPCFP
Parameters / ModelsISL78845ASRHD/PROTO
ISL78845ASRHD/PROTO
ISL78845ASRHF/PROTO
ISL78845ASRHF/PROTO
ISL78845ASRHQD
ISL78845ASRHQD
ISL78845ASRHQF
ISL78845ASRHQF
ISL78845ASRHVD
ISL78845ASRHVD
ISL78845ASRHVF
ISL78845ASRHVF
ISL78845ASRHVX
ClassV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTO
DLA SMD5962-072495962-072495962-072495962-072495962-072495962-072495962-07249
DescriptionRadiation Hardened, High Performance Industry Standard Single-Ended Current Mode PWM ControllerRadiation Hardened, High Performance Industry Standard Single-Ended Current Mode PWM ControllerRadiation Hardened, High Performance Industry Standard Single-Ended Current Mode PWM ControllerRadiation Hardened, High Performance Industry Standard Single-Ended Current Mode PWM ControllerRadiation Hardened, High Performance Industry Standard Single-Ended Current Mode PWM ControllerRadiation Hardened, High Performance Industry Standard Single-Ended Current Mode PWM ControllerRadiation Hardened, High Performance Industry Standard Single-Ended Current Mode PWM Controller
High Dose Rate (HDR) krad(Si)100100100100100100100
Рабочий диапазон температурот -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125
Qualification LevelQML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)
SEL (MeV/mg/cm2)80808080808080
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместим
ISL78840ASEH ISL78840ASRH ISL78841ASEH ISL78841ASRH ISL78843ASEH ISL78843ASRH ISL78845ASEH
  • Space & Harsh Environment > Rad Hard Power > RH Switching Controllers
На английском языке: Datasheet Intersil ISL78845ASRH
