Datasheet Intersil HI5760 — Даташит
Производитель | Intersil |
Серия | HI5760 |
10-Bit, 125/60MSPS, High Speed D/A Converter
Купить HI5760 на РадиоЛоцман.Цены — от 72 до 583 ₽ 26 предложений от 20 поставщиков Цифро-аналоговые преобразователи (ЦАП) D/A 10-BIT 125MSPS 28PIN INDUST TEMP | |||
HI5760BIBZ-T Intersil | 72 ₽ | ||
HI5760IAZ Intersil | 484 ₽ | ||
HI5760/6IB Harris | 578 ₽ | ||
HI5760BIBZ-T Intersil | по запросу |
HI5760/6IB | HI5760/6IBZ | HI5760BIB | HI5760BIB-T | HI5760BIBZ | HI5760BIBZ-T | HI5760IA | HI5760IA-T | HI5760IAZ | HI5760IAZ-T | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 |
Корпус | 28 Ld SOIC | 28 Ld SOIC | 28 Ld SOIC | 28 Ld SOIC T+R | 28 Ld SOIC | 28 Ld SOIC T+R | 28 Ld TSSOP | 28 Ld TSSOP T+R | 28 Ld TSSOP | 28 Ld TSSOP T+R |
Parameters / Models | HI5760/6IB | HI5760/6IBZ | HI5760BIB | HI5760BIB-T | HI5760BIBZ | HI5760BIBZ-T | HI5760IA | HI5760IA-T | HI5760IAZ | HI5760IAZ-T |
± DNL (Diff. Non-Linearity) (LSB) | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 |
± INL (Integral Non-Linearity) (LSB) | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Description | 10-Bit, 125/60MSPS, High Speed D/A Converter | 10-Bit, 125/60MSPS, High Speed D/A Converter | 10-Bit, 125/60MSPS, High Speed D/A Converter | 10-Bit, 125/60MSPS, High Speed D/A Converter | 10-Bit, 125/60MSPS, High Speed D/A Converter | 10-Bit, 125/60MSPS, High Speed D/A Converter | 10-Bit, 125/60MSPS, High Speed D/A Converter | 10-Bit, 125/60MSPS, High Speed D/A Converter | 10-Bit, 125/60MSPS, High Speed D/A Converter | 10-Bit, 125/60MSPS, High Speed D/A Converter |
Max Conv Rate (MSPS) | 60, 125 | 60, 125 | 60, 125 | 60, 125 | 60, 125 | 60, 125 | 60, 125 | 60, 125 | 60, 125 | 60, 125 |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Output I/V | I | I | I | I | I | I | I | I | I | I |
Peak Temp | 240°C | 260°C | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C |
Power (mW) | 27mW at 100Msps (3V) | 27mW at 100Msps (3V) | 27mW at 100Msps (3V) | 27mW at 100Msps (3V) | 27mW at 100Msps (3V) | 27mW at 100Msps (3V) | 27mW at 100Msps (3V) | 27mW at 100Msps (3V) | 27mW at 100Msps (3V) | 27mW at 100Msps (3V) |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
Разрешение | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
SFDR (typ) to Nyquist (dBc) | 68dBc 5MHz@100Msps | 68dBc 5MHz@100Msps | 68dBc 5MHz@100Msps | 68dBc 5MHz@100Msps | 68dBc 5MHz@100Msps | 68dBc 5MHz@100Msps | 68dBc 5MHz@100Msps | 68dBc 5MHz@100Msps | 68dBc 5MHz@100Msps | 68dBc 5MHz@100Msps |
VREF | Int/Ext | Int/Ext | Int/Ext | Int/Ext | Int/Ext | Int/Ext | Int/Ext | Int/Ext | Int/Ext | Int/Ext |
VS (max) | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V |
VS (min) | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V |
В± DNL (Diff. Non-Linearity) (LSB) | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 |
В± INL (Integral Non-Linearity) (LSB) | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: HI5760 (10)
- Data Converters > D/A Converters > D/A Converters
