Datasheet Intersil EL8100 — Даташит
Производитель | Intersil |
Серия | EL8100 |
200MHz Rail-to-Rail Amplifiers
Купить EL8100 на РадиоЛоцман.Цены — от 72 до 10 011 ₽ 21 предложений от 18 поставщиков Voltage Feedback Amplifier 1 Circuit Rail-to-Rail 8-SOIC | |||
EL8100IW-T7 Intersil | 72 ₽ | ||
EL8100ISZ Intersil | 74 ₽ | ||
EL8100IS | от 101 ₽ | ||
EL8100IW-T13 Intersil | по запросу |
EL8100IS | EL8100IS-T13 | EL8100IS-T7 | EL8100ISZ | EL8100ISZ-T13 | EL8100ISZ-T7 | EL8100IW-T7 | EL8100IW-T7A | EL8100IWZ-T7 | EL8100IWZ-T7A | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 |
Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 6 Ld SOT T+R | 6 Ld SOT T+R | 6 Ld SOT T+R | 6 Ld SOT T+R |
Parameters / Models | EL8100IS | EL8100IS-T13 | EL8100IS-T7 | EL8100ISZ | EL8100ISZ-T13 | EL8100ISZ-T7 | EL8100IW-T7 | EL8100IW-T7A | EL8100IWZ-T7 | EL8100IWZ-T7A |
2nd Harmonic | -62 dB | -62 dB | -62 dB | -62 dB | -62 dB | -62 dB | -62 dB | -62 dB | -62 dB | -62 dB |
3rd Harmonic | -65 dB | -65 dB | -65 dB | -65 dB | -65 dB | -65 dB | -65 dB | -65 dB | -65 dB | -65 dB |
AVOL | 90 dB | 90 dB | 90 dB | 90 dB | 90 dB | 90 dB | 90 dB | 90 dB | 90 dB | 90 dB |
Полоса частот | 200 MHz | 200 MHz | 200 MHz | 200 MHz | 200 MHz | 200 MHz | 200 MHz | 200 MHz | 200 MHz | 200 MHz |
Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Коэффициент подавления синфазного сигнала | 90 dB | 90 dB | 90 dB | 90 dB | 90 dB | 90 dB | 90 dB | 90 dB | 90 dB | 90 dB |
Description | 200MHz Rail-to-Rail Amplifiers | 200MHz Rail-to-Rail Amplifiers | 200MHz Rail-to-Rail Amplifiers | 200MHz Rail-to-Rail Amplifiers | 200MHz Rail-to-Rail Amplifiers | 200MHz Rail-to-Rail Amplifiers | 200MHz Rail-to-Rail Amplifiers | 200MHz Rail-to-Rail Amplifiers | 200MHz Rail-to-Rail Amplifiers | 200MHz Rail-to-Rail Amplifiers |
Diff Gain (%) | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 |
Diff Phase (В°) | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 |
Distortion Conditions | 2Vpp, 10MHz | 2Vpp, 10MHz | 2Vpp, 10MHz | 2Vpp, 10MHz | 2Vpp, 10MHz | 2Vpp, 10MHz | 2Vpp, 10MHz | 2Vpp, 10MHz | 2Vpp, 10MHz | 2Vpp, 10MHz |
Enable | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Gain AV (min) | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
IBIAS | 1.5 μA | 1.5 μA | 1.5 μA | 1.5 μA | 1.5 μA | 1.5 μA | 1.5 μA | 1.5 μA | 1.5 μA | 1.5 μA |
IBIAS (max) | 2.1 μA | 2.1 μA | 2.1 μA | 2.1 μA | 2.1 μA | 2.1 μA | 2.1 μA | 2.1 μA | 2.1 μA | 2.1 μA |
IOUT | 65 mA | 65 mA | 65 mA | 65 mA | 65 mA | 65 mA | 65 mA | 65 mA | 65 mA | 65 mA |
IS (per amp) | 2 mA | 2 mA | 2 mA | 2 mA | 2 mA | 2 mA | 2 mA | 2 mA | 2 mA | 2 mA |
Noise VN | 10 nV/√Hz | 10 nV/√Hz | 10 nV/√Hz | 10 nV/√Hz | 10 nV/√Hz | 10 nV/√Hz | 10 nV/√Hz | 10 nV/√Hz | 10 nV/√Hz | 10 nV/√Hz |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Output Headroom | 0.1 V | 0.1 V | 0.1 V | 0.1 V | 0.1 V | 0.1 V | 0.1 V | 0.1 V | 0.1 V | 0.1 V |
PSRR | 100 dB | 100 dB | 100 dB | 100 dB | 100 dB | 100 dB | 100 dB | 100 dB | 100 dB | 100 dB |
Peak Temp | 240°C | 240°C | 240°C | 260°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
Rail-to-Rail Input | -Vs | -Vs | -Vs | -Vs | -Vs | -Vs | -Vs | -Vs | -Vs | -Vs |
Rail-to-Rail Output | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Скорость нарастания | 200 V/μs | 200 V/μs | 200 V/μs | 200 V/μs | 200 V/μs | 200 V/μs | 200 V/μs | 200 V/μs | 200 V/μs | 200 V/μs |
Thermal Shutdown | No | No | No | No | No | No | No | No | No | No |
Topology | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA |
VOS (max) | 6 mV | 6 mV | 6 mV | 6 mV | 6 mV | 6 mV | 6 mV | 6 mV | 6 mV | 6 mV |
VOUT | 4.8 V | 4.8 V | 4.8 V | 4.8 V | 4.8 V | 4.8 V | 4.8 V | 4.8 V | 4.8 V | 4.8 V |
VS (max) | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V |
VS (min) | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: EL8100 (10)
- Amplifiers & Buffers > All Amplifiers > Amplifiers
