Datasheet Linear Technology LT4180MPGN#TRPBF — Даташит
Серия | LT4180 |
Модель | LT4180MPGN#TRPBF |
Virtual Remote Sense Controller
LT4180 - Virtual Remote Sense Controller
PDF, 358 Кб, Версия: B, Файл закачен: 12 ноя 2017
Купить LT4180MPGN#TRPBF на РадиоЛоцман.Цены — от 698 до 878 ₽ 19 предложений от 13 поставщиков Power Supply Controller Power Supply Controller 24-SSOP | |||
LT4180MPGN#TRPBF Analog Devices | 698 ₽ | ||
LT4180MPGN#TRPBF Analog Devices | от 708 ₽ | ||
LT4180MPGN#TRPBF Linear Technology | по запросу | ||
LT4180MPGN#TRPBF Analog Devices | по запросу |
Корпус | SSOP-24 |
Код корпуса | GN |
Индекс корпуса | 05-08-1641 (GN24) |
Demo Boards | DC1504A |
Design Tools | LTspice File |
Экспортный контроль | нет |
Основные особенности | Virtual Remote Sense |
Isupply | 1 мА |
Number of Supplies | 1 |
Рабочий диапазон температур | от -55 до 125 °C |
Vin Max | 50 В |
Vin Min | 3.1 В |
- 2-Wire Virtual Remote Sensing for Voltage Regulators - Clairvoyance Marries Remote Sensing &mdash AN126PDF, 1.4 Мб, Файл опубликован: 1 окт 2010
Wires and connectors have resistance. This simple, unavoidable truth dictates that a power source’s remote load voltage will be less than the source’s output voltage. Traditional methods for countering this include increasing the power source voltage and "4-wire" remote voltage sensing. Both have limitations. A new IC based approach achieves "virtual" remote sensing at the load without adding the usual two extra sense wires. Numerous circuit examples show the IC working with various voltage regulators and remote loads. Appendices detail IC internal operation and design guidelines for applying the part in any regulator circuit.Выписка из документа
Design Notes
- Tighten Supply Regulation for 2A USB Devices by Dynamically Compensating for Voltage Drops in Wiring and Connectors &mdash DN1029PDF, 121 Кб, Файл опубликован: 27 фев 2013Выписка из документа
Статьи
- Virtual Remote Sensing Improves Load Regulation by Compensating for Wiring Drops Without Remote Sense Lines &mdash LT JournalPDF, 1.8 Мб, Файл опубликован: 30 июн 2010Выписка из документа
Серия: LT4180 (6)
- LT4180EGN#PBF LT4180EGN#TRPBF LT4180IGN#PBF LT4180IGN#TRPBF LT4180MPGN#PBF LT4180MPGN#TRPBF
- Monitor, Control and Protection > Cable Drop Compensation
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Power Management
LT4180MPGNTRPBF, LT4180MPGN TRPBF
