Datasheet Microchip PIC16F18856T-E/SO — Даташит
Производитель | Microchip |
Серия | PIC16F18856 |
Модель | PIC16F18856T-E/SO |
PIC16(L)F1885X/7X microcontrollers feature Analog, Core Independent Peripherals and communication peripherals, combined with eXtreme Low Power (XLP) for a wide range of general purpose and low-power applications.
Datasheet PIC16(L)F18856/76
PDF, 10.3 Мб, Язык: анг., Файл закачен: 8 ноя 2019, Страниц: 675
Full-Featured 28/40/44-Pin Microcontrollers
Купить PIC16F18856T-E на РадиоЛоцман.Цены — от 113 до 284 ₽ 18 предложений от 9 поставщиков PIC PIC® XLPTM16F, Functional Safety (FuSa) Microcontroller IC 8-Bit 32MHz 28KB (16K x 14) FLASH 28-QFN (6x6) | |||
PIC16F18856T-I/MV Microchip | 113 ₽ | ||
PIC16F18856T-I/MV Microchip | 115 ₽ | ||
PIC16F18856T-I/MV Microchip | от 120 ₽ | ||
PIC16F18856T-I/ML Microchip | по запросу |
The family features the CRC/SCAN, HLT and Windowed WDT to support customers looking to add safety to their application. Additionally, this family includes up to 56 KB of Flash memory, along with a 10-bit ADC with Computation (ADC2) for automated signal analysis to reduce the complexity of the application.
Корпус | SOIC |
ADC Input | 24 |
ADC with Computation | Yes |
ADC with Enhanced Features | Yes |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | Yes |
Class B Support | No |
Complementary Waveform Generator / Complementary Output Generator | 3 |
Configurable Logic Cell | 4 CLC/CCL |
Data Signal Modulator | 1 |
Emulated EEPROM in Flash | 256 |
Hardware Limit Timer | 3 |
Hardware Touch Peripheral | ADC2 with HCVD |
High Voltage Capable | No |
I2C | 2 |
Lead Count | 28 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 4 |
Max 8-Bit Digital Timers | 3 |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 5 Bits |
Max PWM outputs | 19 including complementary |
Количество компараторов | 2 |
Number of DACs | 1 |
Numerically Controlled Oscillator | 1 |
Package Width | .300in |
Pin count | 28 |
Размер памяти программ | 28 KB |
SPI | 2 |
SRAM | 2048 Bytes |
Signal Measurement Timer | 2 |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | Yes |
Серия: PIC16F18856 (51)
- PIC16F18856-E/ML PIC16F18856-E/MLVAO PIC16F18856-E/MV PIC16F18856-E/SO PIC16F18856-E/SP PIC16F18856-E/SS PIC16F18856-E/STX PIC16F18856-E/STXVAO PIC16F18856-I/ML PIC16F18856-I/MLVAO PIC16F18856-I/MV PIC16F18856-I/SO PIC16F18856-I/SP PIC16F18856-I/SS PIC16F18856-I/SSVAO PIC16F18856-I/STX PIC16F18856T-E/MLVAO PIC16F18856T-E/MV PIC16F18856T-E/SO PIC16F18856T-E/SS PIC16F18856T-E/SSVAO PIC16F18856T-E/STXVAO PIC16F18856T-I/ML PIC16F18856T-I/MLC01 PIC16F18856T-I/MLVAO PIC16F18856T-I/MV PIC16F18856T-I/SO PIC16F18856T-I/SS PIC16F18856T-I/SSVAO PIC16F18856T-I/STX PIC16F18856T-I/STXJUUL PIC16LF18856-E/ML PIC16LF18856-E/MV PIC16LF18856-E/SO PIC16LF18856-E/SP PIC16LF18856-E/SS PIC16LF18856-E/STX PIC16LF18856-I/ML PIC16LF18856-I/MLVAO PIC16LF18856-I/MV PIC16LF18856-I/SO PIC16LF18856-I/SP PIC16LF18856-I/SS PIC16LF18856-I/STX PIC16LF18856T-E/MV PIC16LF18856T-I/ML PIC16LF18856T-I/MLVAO PIC16LF18856T-I/MV PIC16LF18856T-I/SO PIC16LF18856T-I/SS PIC16LF18856T-I/STX
- 8-bit Microcontrollers > PIC16 MCU
PIC16F18856TE/SO, PIC16F18856T E/SO
