Datasheet Microchip PIC18LF66K40T-I/MR — Даташит
Производитель | Microchip |
Серия | PIC18F66K40 |
Модель | PIC18LF66K40T-I/MR |
PIC18(L)F66K40 microcontrollers combine large Flash/EE/RAM memory, rich peripheral integration, XLP and 5V support to suit a variety of general purpose applications
Datasheet PIC18F65K40, PIC18F66K40, PIC18LF65K40, PIC18LF66K40
PDF, 6.6 Мб, Язык: анг., Файл закачен: 11 ноя 2017, Страниц: 872
64-Pin, Low-Power, High-Performance Microcontrollers with XLP Technology
Купить PIC18LF66K40T-I/MR на РадиоЛоцман.Цены — от 189 до 555 ₽ 11 предложений от 8 поставщиков PIC PIC® XLPTM18K Microcontroller IC 8-Bit 64MHz 64KB (32K x 16) FLASH 64-VQFN (9x9) | |||
PIC18LF66K40T-I/MR Microchip | 189 ₽ | ||
PIC18LF66K40T-I/MR Microchip | 191 ₽ | ||
PIC18LF66K40T-I/MR Microchip | от 555 ₽ | ||
PIC18LF66K40T-I/MR Microchip | по запросу |
Корпус | QFN |
Количество выводов | 64 |
ADC Input | 47 |
ADC with Computation | Yes |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | Yes |
Class B Hardware | Yes |
Complementary Waveform Generator / Complementary Output Generator | 1 |
Data Signal Modulator | 1 |
Emulated EEPROM in Flash | 1024 |
Hardware Limit Timer | 1 |
Hardware Touch Peripheral | ADC2 with HCVD |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | 64MHZ, 64KHz |
Math Accelerator | No |
Max 16-Bit Digital Timers | 4 |
Max 8-Bit Digital Timers | 5 |
Max CPU Speed | 64 МГц |
Max DAC Resolution | 5 Bits |
Max PWM outputs | 5 including complementary |
Количество компараторов | 3 |
Number of DACs | 1 |
Pin count | 64 |
Размер памяти программ | 64 KB |
SPI | 2 |
SRAM | 3562 Bytes |
Signal Measurement Timer | 2 |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 5 |
Zero Cross detect | Yes |
Серия: PIC18F66K40 (15)
- Microcontrollers > 8-bit Microcontrollers
PIC18LF66K40TI/MR, PIC18LF66K40T I/MR
