Datasheet Microchip PIC18F56K42-E/MV — Даташит
Производитель | Microchip |
Серия | PIC18F56K42 |
Модель | PIC18F56K42-E/MV |
PIC18(L)FxxK42 MCUs integrate a rich set of core independent peripherals, intelligent analog peripherals and large Flash/RAM/EEPROM memories.
Datasheet PIC18(L)F26/27/45/46/47/55/56/57K42
PDF, 11.3 Мб, Язык: анг., Файл закачен: 13 ноя 2019, Страниц: 833
28/40/44/48-Pin, Low-Power High-Performance Microcontrollers with XLP Technology
Datasheet PIC18(L)F2X/4X/5XK42
PDF, 208 Кб, Язык: анг., Файл закачен: 13 ноя 2019, Страниц: 18
Highly Integrated 8-Bit PIC Microcontrollers in 28-to 48-Pins
Купить PIC18F56K42-E/MV на РадиоЛоцман.Цены — от 189 до 17 302 ₽ 12 предложений от 8 поставщиков PIC PIC® XLPTM18K Microcontroller IC 8-Bit 64MHz 64KB (32K x 16) FLASH 48-UQFN (6x6) | |||
PIC18F56K42-E/MV Microchip | 189 ₽ | ||
PIC18F56K42-E/MV Microchip | 191 ₽ | ||
PIC18F56K42-E/MV Microchip | от 555 ₽ | ||
PIC18F56K42-E/MV Microchip | по запросу |
These 28-, 40- and 48-pin devices also offer a host of low power features, performance improvements and design flexibility options that easily and rapidly enable the complex set of functions required by many of today's embedded control applications.
Корпус | UQFN |
ADC Input | 43 |
ADC with Computation | Yes |
ADC with Enhanced Features | Yes |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | Yes |
Class B Support | Yes |
Complementary Waveform Generator / Complementary Output Generator | 3 |
Configurable Logic Cell | 4 CLC/CCL |
Data Signal Modulator | 1 |
Emulated EEPROM in Flash | 1024 |
Hardware Limit Timer | 3 |
Hardware Touch Peripheral | ADC2 with HCVD |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | 64MHZ, 64KHz |
Lead Count | 48 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 4 |
Max 8-Bit Digital Timers | 3 |
Max ADC Resolution | 12 Bits |
Max CPU Speed | 64 МГц |
Max DAC Resolution | 5 Bits |
Количество компараторов | 2 |
Number of DACs | 1 |
Numerically Controlled Oscillator | 1 |
Package Width | 6x6x0.5mm |
Pin count | 48 |
Размер памяти программ | 64 KB |
SPI | 1 |
SRAM | 4096 Bytes |
Signal Measurement Timer | 1 |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 2 |
Zero Cross detect | Yes |
PIC18F27K42 PIC18F45K42 PIC18F46K42 PIC18F47K42 PIC18F55K42 PIC18F57K42
Серия: PIC18F56K42 (13)
- 8-bit Microcontrollers > PIC18 MCU
PIC18F56K42E/MV, PIC18F56K42 E/MV
