Datasheet Microchip DSPIC33FJ64MC506AT-I/PT — Даташит
Производитель | Microchip |
Серия | dsPIC33FJ64MC506A |
Модель | DSPIC33FJ64MC506AT-I/PT |
dsPIC33F Motor Control Digital Signal Controller (DSC) with seamless migration options to PIC24 MCUs and dsPIC30F DSCs in similar packages
Купить DSPIC33FJ64MC506AT-I/PT на РадиоЛоцман.Цены — от 319 до 1 190 ₽ 9 предложений от 9 поставщиков dsPIC dsPICTM33F Microcontroller IC 16-Bit 40 MIPs 64KB (64K x 8) FLASH 64-TQFP (10x10) | |||
DSPIC33FJ64MC506AT-I/PT Microchip | 319 ₽ | ||
DSPIC33FJ64MC506AT-I/PT Microchip | 489 ₽ | ||
DSPIC33FJ64MC506AT-I/PT Microchip | по запросу | ||
Корпус | TQFP |
Количество выводов | 64 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit dsPIC DSC |
CRC/Scan | No |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | 7.37 MHz, 32.768 kHz |
Math Accelerator | No |
Max # PWM outputs | 16 including complementary outputs |
Max 16 Bit Digital Timers | 9 |
Max. CPU Speed MHz | 40 |
Operation Voltage Min.(V) | 3 |
Peripheral Pin Select | No PPS |
Pin count | 64 |
Размер памяти программ | 64 Kbytes |
RAM | 8192 bytes |
SPIв„ў | 2 |
Temp. Range Max. | 150 |
Temp. Range Min. | -40 |
Total # of A/D channels | 16 |
UART | 2 |
Zero Cross detect | No |
dsPIC33FJ128MC506A dsPIC33FJ128MC510A dsPIC33FJ128MC706A dsPIC33FJ128MC708A dsPIC33FJ128MC710A dsPIC33FJ256MC510A dsPIC33FJ256MC710A dsPIC33FJ64MC508A dsPIC33FJ64MC510A dsPIC33FJ64MC706A dsPIC33FJ64MC710A
Серия: dsPIC33FJ64MC506A (14)
- DSPIC33FJ64MC506A-E/MR DSPIC33FJ64MC506A-E/PT DSPIC33FJ64MC506A-H/MR DSPIC33FJ64MC506A-H/PT DSPIC33FJ64MC506A-I/MR DSPIC33FJ64MC506A-I/PT DSPIC33FJ64MC506A-I/PTVAO DSPIC33FJ64MC506AT-E/MR DSPIC33FJ64MC506AT-E/PT DSPIC33FJ64MC506AT-H/MR DSPIC33FJ64MC506AT-H/PT DSPIC33FJ64MC506AT-I/MR DSPIC33FJ64MC506AT-I/PT DSPIC33FJ64MC506AT-I/PTVAO
DSPIC33FJ64MC506ATI/PT, DSPIC33FJ64MC506AT I/PT
