Datasheet Microchip DSPIC33FJ32GP202-E/SP — Даташит
Производитель | Microchip |
Серия | dsPIC33FJ32GP202 |
Модель | DSPIC33FJ32GP202-E/SP |
16-bit Sensor and General Purpose family dsPIC33F Digital Signal Controller in low-pin count packages featuring the new Peripheral Pin Select capability
dsPIC33FJ32GP202/204 and dsPIC33FJ16GP304 Data Sheet
PDF, 4.6 Мб, Версия: 06-07-2012
Купить DSPIC33FJ32GP202-E/SP на РадиоЛоцман.Цены — от 244 до 910 ₽ 9 предложений от 9 поставщиков dsPIC Automotive, AEC-Q100, dsPICTM33F Microcontroller IC 16-Bit 40 MIPs 32KB (32K x 8) FLASH 28-SPDIP | |||
DSPIC33FJ32GP202-E/SP Microchip | 244 ₽ | ||
DSPIC33FJ32GP202-E/SP Microchip | 409 ₽ | ||
DSPIC33FJ32GP202-E/SP Microchip | 897 ₽ | ||
DSPIC33FJ32GP202-E/SP Microchip | по запросу |
Корпус | SPDIP |
Количество выводов | 28 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit dsPIC DSC |
CRC/Scan | No |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 7.37 MHz, 32.768 kHz |
Math Accelerator | No |
Max # PWM outputs | 2 including complementary outputs |
Max 16 Bit Digital Timers | 3 |
Max. CPU Speed MHz | 40 |
Рабочий диапазон температур | от -40 до +125 °C |
Operation Voltage Min.(V) | 3 |
Pin count | 28 |
Размер памяти программ | 32 Kbytes |
RAM | 2048 bytes |
SPIв„ў | 1 |
Temp. Range Max. | 125 |
Temp. Range Min. | -40 |
Total # of A/D channels | 10 |
UART | 1 |
Zero Cross detect | No |
dsPIC33FJ16GP304 dsPIC33FJ32GP204
Серия: dsPIC33FJ32GP202 (14)
- DSPIC33FJ32GP202-E/MM DSPIC33FJ32GP202-E/SO DSPIC33FJ32GP202-E/SP DSPIC33FJ32GP202-E/SS DSPIC33FJ32GP202-I/MM DSPIC33FJ32GP202-I/SO DSPIC33FJ32GP202-I/SP DSPIC33FJ32GP202-I/SS DSPIC33FJ32GP202T-E/MM DSPIC33FJ32GP202T-E/SO DSPIC33FJ32GP202T-E/SS DSPIC33FJ32GP202T-I/MM DSPIC33FJ32GP202T-I/SO DSPIC33FJ32GP202T-I/SS
DSPIC33FJ32GP202E/SP, DSPIC33FJ32GP202 E/SP
