Datasheet Microchip DSPIC33EV64GM002-H/SS — Даташит
СерияdsPIC33EV64GM002
МодельDSPIC33EV64GM002-H/SS
Microchip’s dsPIC33EV family of digital signal controllers (DSCs) features a 5V 70 MIPS dsPIC® DSC core with enhanced on-chip features and is ideal for operating in harsh environments such as appliances and automotive applications
dsPIC33EVXXXGM00X/10X Family Data Sheet
PDF, 4.4 Мб, Версия: 09-26-2016
Utmel
DSPIC33EV64GM002-H/SP
Электромеханические реле Hongfa – надежность и качество 19 января 2023
КорпусSSOP
Количество выводов28
# of Comparators5
ADCC with ComputationNo
Angular TimerNo
Архитектура16
CPU16-bit dsPIC DSC
CRC/ScanNo
EEPROM / HEF0 / HEF
High Voltage CapableNo
I2C1
Math AcceleratorNo
Max # PWM outputs10 including complementary outputs
Max 16 Bit Digital Timers5
Max A/D Resolution12 bits
Max D/A Resolution7 bits
Max PWM Resolution16 bits
Max. CPU Speed MHz70
Number of D/A Converters1
Рабочий диапазон температурот -40 до >+125 °C
Operation Voltage Max.(V)5.5
Operation Voltage Min.(V)4.5
Operational Amplifier4
Peripheral Pin SelectYes PPS
Pin count28
Размер памяти программ64 Kbytes
RAM4096 bytes
SPIв„ў2
Temp. Range Max.150
Temp. Range Min.-40
Total # of A/D channels36
UART2
Zero Cross detectNo
dsPIC33EV128GM002 dsPIC33EV128GM004 dsPIC33EV128GM006 dsPIC33EV128GM102 dsPIC33EV128GM104 dsPIC33EV128GM106 dsPIC33EV256GM002 dsPIC33EV256GM004 dsPIC33EV256GM006 dsPIC33EV256GM102 dsPIC33EV256GM104 dsPIC33EV256GM106 dsPIC33EV32GM002 dsPIC33EV32GM004 dsPIC33EV32GM006 dsPIC33EV32GM102 dsPIC33EV32GM104 dsPIC33EV32GM106 dsPIC33EV64GM004 dsPIC33EV64GM006 dsPIC33EV64GM102 dsPIC33EV64GM104 dsPIC33EV64GM106
DSPIC33EV64GM002H/SS, DSPIC33EV64GM002 H/SS
На английском языке: Datasheet Microchip DSPIC33EV64GM002-H/SS
