Datasheet Microchip DSPIC33EV256GM104T-I/ML — Даташит
Производитель | Microchip |
Серия | dsPIC33EV256GM104 |
Модель | DSPIC33EV256GM104T-I/ML |
Microchip’s dsPIC33EV family of digital signal controllers (DSCs) features a 5V 70 MIPS dsPIC® DSC core with enhanced on-chip features and is ideal for operating in harsh environments such as appliances and automotive applications
Купить DSPIC33EV256GM104T-I/ML на РадиоЛоцман.Цены — от 72 до 891 ₽ 8 предложений от 8 поставщиков dsPIC dsPICTM33EV, Functional Safety (FuSa) Microcontroller IC 16-Bit 70 MIPs 256KB (85.5K x 24) FLASH 44-QFN (8x8) | |||
DSPIC33EV256GM104T-I/ML Microchip | 72 ₽ | ||
DSPIC33EV256GM104T-I/ML Microchip | 358 ₽ | ||
DSPIC33EV256GM104T-I/ML Microchip | 891 ₽ | ||
DSPIC33EV256GM104T-I/ML Microchip | по запросу |
Корпус | QFN |
Количество выводов | 44 |
# of Comparators | 5 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit dsPIC DSC |
CRC/Scan | No |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 7.37 MHz, 32 kHz |
Math Accelerator | No |
Max # PWM outputs | 10 including complementary outputs |
Max D/A Resolution | 7 bits |
Max. CPU Speed MHz | 70 |
Operation Voltage Max.(V) | 5.5 |
Operation Voltage Min.(V) | 4.5 |
Operational Amplifier | 4 |
Pin count | 44 |
Размер памяти программ | 256 Kbytes |
RAM | 16384 bytes |
SPIв„ў | 2 |
Temp. Range Max. | 150 |
Temp. Range Min. | -40 |
Total # of A/D channels | 24 |
UART | 2 |
Zero Cross detect | No |
dsPIC33EV128GM002 dsPIC33EV128GM004 dsPIC33EV128GM006 dsPIC33EV128GM102 dsPIC33EV128GM104 dsPIC33EV128GM106 dsPIC33EV256GM002 dsPIC33EV256GM004 dsPIC33EV256GM006 dsPIC33EV256GM102 dsPIC33EV256GM106 dsPIC33EV32GM002 dsPIC33EV32GM004 dsPIC33EV32GM006 dsPIC33EV32GM102 dsPIC33EV32GM104 dsPIC33EV32GM106 dsPIC33EV64GM002 dsPIC33EV64GM004 dsPIC33EV64GM006 dsPIC33EV64GM102 dsPIC33EV64GM104 dsPIC33EV64GM106
Серия: dsPIC33EV256GM104 (8)
DSPIC33EV256GM104TI/ML, DSPIC33EV256GM104T I/ML
