Datasheet Microchip DSPIC33EP128GM706-I/MR — Даташит
Производитель | Microchip |
Серия | dsPIC33EP128GM706 |
Модель | DSPIC33EP128GM706-I/MR |
Microchip’s dsPIC33E family of digital signal controllers (DSCs) features a 70 MIPS dsPIC® DSC core with integrated DSP and enhanced on-chip peripherals
Купить DSPIC33EP128GM706-I/MR на РадиоЛоцман.Цены — от 345 до 1 628 ₽ 20 предложений от 13 поставщиков dsPIC dsPICTM33EP Microcontroller IC 16-Bit 70 MIPs 128KB (43K x 24) FLASH 64-VQFN (9x9) | |||
DSPIC33EP128GM706-I/MR Microchip | 345 ₽ | ||
DSPIC33EP128GM706-I/MR Microchip | 517 ₽ | ||
DSPIC33EP128GM706-I/MR Microchip | от 591 ₽ | ||
DSPIC33EP128GM706-I/MR Microchip | 1 268 ₽ |
Корпус | QFN |
Количество выводов | 64 |
# of Comparators | 5 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit dsPIC DSC |
CRC/Scan | Yes |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | 7.37 MHz, 32 kHz |
Math Accelerator | No |
Max # PWM outputs | 20 including complementary outputs |
Max 16 Bit Digital Timers | 9 |
Max D/A Resolution | 4 bits |
Max. CPU Speed MHz | 70 |
Number of D/A Converters | 2 |
Operation Voltage Min.(V) | 3 |
Operational Amplifier | 4 |
Pin count | 64 |
Размер памяти программ | 128 Kbytes |
RAM | 16384 bytes |
SPIв„ў | 3 |
Temp. Range Max. | 125 |
Temp. Range Min. | -40 |
Total # of A/D channels | 30 |
UART | 4 |
Zero Cross detect | No |
dsPIC33EP128GM304 dsPIC33EP128GM306 dsPIC33EP128GM310 dsPIC33EP128GM604 dsPIC33EP128GM710 dsPIC33EP256GM304 dsPIC33EP256GM306 dsPIC33EP256GM310 dsPIC33EP256GM604 dsPIC33EP256GM706 dsPIC33EP256GM710 dsPIC33EP512GM304 dsPIC33EP512GM306 dsPIC33EP512GM310 dsPIC33EP512GM604 dsPIC33EP512GM706 dsPIC33EP512GM710
Серия: dsPIC33EP128GM706 (8)
DSPIC33EP128GM706I/MR, DSPIC33EP128GM706 I/MR
