Datasheet Microchip DSPIC33EP128GM304-E/PT — Даташит
Производитель | Microchip |
Серия | dsPIC33EP128GM304 |
Модель | DSPIC33EP128GM304-E/PT |
Microchip’s dsPIC33E family of digital signal controllers (DSCs) features a 70 MIPS dsPIC® DSC core with integrated DSP and enhanced on-chip peripherals
Купить DSPIC33EP128GM304-E/PT на РадиоЛоцман.Цены — от 251 до 1 512 ₽ 15 предложений от 12 поставщиков dsPIC Automotive, AEC-Q100, dsPICTM33EP Microcontroller IC 16-Bit 60 MIPs 128KB (43K x 24) FLASH 44-TQFP (10x10) | |||
DSPIC33EP128GM304-E/PT Microchip | от 251 ₽ | ||
DSPIC33EP128GM304-E/PT Microchip | 334 ₽ | ||
DSPIC33EP128GM304-E/PT Microchip | 1 168 ₽ | ||
DSPIC33EP128GM304-E/PT Microchip | 1 246 ₽ |
Корпус | TQFP |
Количество выводов | 44 |
# of Comparators | 5 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit dsPIC DSC |
CRC/Scan | Yes |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | 7.37 MHz, 32 kHz |
Math Accelerator | No |
Max # PWM outputs | 20 including complementary outputs |
Max 16 Bit Digital Timers | 9 |
Max D/A Resolution | 4 bits |
Max. CPU Speed MHz | 70 |
Number of D/A Converters | 2 |
Рабочий диапазон температур | от -40 до +125 °C |
Operation Voltage Min.(V) | 3 |
Operational Amplifier | 4 |
Pin count | 44 |
Размер памяти программ | 128 Kbytes |
RAM | 16384 bytes |
SPIв„ў | 3 |
Temp. Range Max. | 125 |
Temp. Range Min. | -40 |
Total # of A/D channels | 18 |
UART | 4 |
Zero Cross detect | No |
dsPIC33EP128GM306 dsPIC33EP128GM310 dsPIC33EP128GM604 dsPIC33EP128GM706 dsPIC33EP128GM710 dsPIC33EP256GM304 dsPIC33EP256GM306 dsPIC33EP256GM310 dsPIC33EP256GM604 dsPIC33EP256GM706 dsPIC33EP256GM710 dsPIC33EP512GM304 dsPIC33EP512GM306 dsPIC33EP512GM310 dsPIC33EP512GM604 dsPIC33EP512GM706 dsPIC33EP512GM710
Серия: dsPIC33EP128GM304 (4)
- DSPIC33EP128GM304-E/ML DSPIC33EP128GM304-E/PT DSPIC33EP128GM304-I/ML DSPIC33EP128GM304-I/PT
DSPIC33EP128GM304E/PT, DSPIC33EP128GM304 E/PT
