Datasheet Microchip ATSAME53N20A-AUT — Даташит
Производитель | Microchip |
Серия | ATSAME53N20A |
Модель | ATSAME53N20A-AUT |
The SAM E53 high performance micro-controller series features a 32-bit ARM® Cortex®-M4 processor with Floating Point Unit (FPU), running up to 120 MHz ,up to 1 MB Dual Panel Flash with ECC, and up to 256 KB of SRAM with ECC
Купить ATSAME53N20A-AUT на РадиоЛоцман.Цены — от 515 до 1 506 ₽ 13 предложений от 7 поставщиков ARM® Cortex®-M4F SAM E53 Microcontroller IC 32-Bit Single-Core 120MHz 1MB (1M x 8) FLASH 100-TQFP (14x14) | |||
ATSAME53N20A-AUT Microchip | от 515 ₽ | ||
ATSAME53N20A-AUT-EFP Microchip | 573 ₽ | ||
ATSAME53N20A-AUT-EFP Microchip | 582 ₽ | ||
ATSAME53N20A-AUT Microchip | по запросу |
Корпус | TQFP |
Количество выводов | 100 |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | Cortex-M4F |
CRC/Scan | Yes |
Complementary Waveform Generator | 23 CWG) / Complementary Output Gene |
Configurable Logic Cell Modules | 1 CLC |
EEPROM / HEF | 0 / HEF |
Hardware Touch Peripheral | PTC |
I2C | 8 |
Internal Oscillator | 8,16,24Mhz,32Khz |
Math Accelerator | No |
Max # PWM outputs | 33 including complementary outputs |
Max 16 Bit Digital Timers | 13 |
Max 8 Bit Digital Timers | 13 |
Max D/A Resolution | 12 bits |
Max PWM Resolution | 32 bits |
Max. CPU Speed MHz | 120 |
Number of USB Modules | 1 |
Operation Voltage Min.(V) | 1.71 |
Pin count | 100 |
Размер памяти программ | 1024 Kbytes |
RAM | 262144 bytes |
SPIв„ў | 8 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 28 |
UART | 8 |
Zero Cross detect | No |
ATSAMD51G18A ATSAMD51G19A ATSAMD51J18A ATSAMD51J19A ATSAMD51J20A ATSAMD51N19A ATSAMD51N20A ATSAMD51P19A ATSAMD51P20A ATSAME51J18A ATSAME51J19A ATSAME51J20A ATSAME51N19A ATSAME51N20A ATSAME53J18A ATSAME53J19A ATSAME53J20A ATSAME53N19A ATSAME54N19A ATSAME54N20A ATSAME54P19A ATSAME54P20A
Серия: ATSAME53N20A (2)
- ATSAME53N20A-AU ATSAME53N20A-AUT
ATSAME53N20AAUT, ATSAME53N20A AUT
