Datasheet Microchip ATSAMD51G19A-MU — Даташит
Производитель | Microchip |
Серия | ATSAMD51G19A |
Модель | ATSAMD51G19A-MU |
The SAM D51 high performance micro-controller series is targeted for general purpose applications using the 32-bit ARM® Cortex®-M4 processor with Floating Point Unit (FPU), running up to 120 MHz ,up to 1 MB Dual Panel Flash with ECC, and up to 256 KB of SRAM with ECC
Купить ATSAMD51G19A-MU на РадиоЛоцман.Цены — от 360 до 30 682 ₽ 21 предложений от 11 поставщиков ARM® Cortex®-M4F SAM D51 Microcontroller IC 32-Bit Single-Core 120MHz 512KB (512K x 8) FLASH 48-QFN (7x7) | |||
ATSAMD51G19A-MU-EFP Microchip | 360 ₽ | ||
ATSAMD51G19A-MU-EFP Microchip | 365 ₽ | ||
ATSAMD51G19A-MU Microchip | 441 ₽ | ||
ATSAMD51G19A-MU Microchip | от 1 107 ₽ |
Корпус | VQFN |
Количество выводов | 48 |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | Cortex-M4F |
CRC/Scan | Yes |
Complementary Waveform Generator | 19 CWG) / Complementary Output Gene |
Configurable Logic Cell Modules | 1 CLC |
EEPROM / HEF | 0 / HEF |
Hardware Touch Peripheral | PTC |
I2C | 6 |
Internal Oscillator | 8,16,24Mhz,32Khz |
Math Accelerator | No |
Max # PWM outputs | 21 including complementary outputs |
Max 16 Bit Digital Timers | 7 |
Max 8 Bit Digital Timers | 7 |
Max D/A Resolution | 12 bits |
Max PWM Resolution | 32 bits |
Max. CPU Speed MHz | 120 |
Number of USB Modules | 1 |
Operation Voltage Min.(V) | 1.71 |
Pin count | 48 |
Размер памяти программ | 512 Kbytes |
RAM | 196608 bytes |
SPIв„ў | 6 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 20 |
UART | 6 |
Zero Cross detect | No |
ATSAMD51G18A ATSAMD51J18A ATSAMD51J19A ATSAMD51J20A ATSAMD51N19A ATSAMD51N20A ATSAMD51P19A ATSAMD51P20A ATSAME51J18A ATSAME51J19A ATSAME51J20A ATSAME51N19A ATSAME51N20A ATSAME53J18A ATSAME53J19A ATSAME53J20A ATSAME53N19A ATSAME53N20A ATSAME54N19A ATSAME54N20A ATSAME54P19A ATSAME54P20A
Серия: ATSAMD51G19A (2)
- ATSAMD51G19A-MU ATSAMD51G19A-MUT
ATSAMD51G19AMU, ATSAMD51G19A MU
